New Static IP
New Static IP
Hello i was wanting to get a new Static IP address and should i just raise a ticket asking for this, in what way should i ask if so?
New Static IP
if you have a valid reason ask on the ticket process to be considered
New Static IP
Hi there.
It depends on what you mean. Your account will usually come with a static IP address included. If you mean you'd like and additional IP address, then you are correct. You need to raise a ticket, giving the reason you require an additional address and that will be replied to and processed as necessary.
Hope this answers your question.
New Static IP
Same goes if you simply need / want to change your IP.
Chris
