New Netgear DG834G Beta Firmware out
See http://kbserver.netgear.com/release_notes/D102685.asp
Modifications and Bug Fixes
Version 2.10.17
1. Updated the ADSL driver to improve ADSL2+ support.
2. Added Knowledge Base and Documentation links under Web Support to the web management interface.
3. Moved VPN pages to the Advanced-VPN section.
4. Added VPN keep alive feature on VPN Policies page.
5. Fixed a problem with keyword blocking
6. Extended username and password fields on the E-mail page to 63 characters
7. Fixed a problem where if an SSID, passphrase, or PSK contained a space, it would not be properly restored from the configuration file.
8. Fixed a problem where the date header was missing from email sent by the DG834(G).
9. Port type is now shown on the Services page (under Security).
10. Fixed a problem with PPTP passthrough introduced in 2.10.09.
11. Fixed a problem with a special configuration where the router would not disconnect after idle timeout.
12. Fixed a problem where a long pre-shared key could be entered on the VPN Auto Policy page which could impact router operation. The pre-shared key is now limited to 49 characters.
13. Fixed a problem where the DNS proxy could fail over time.
14. Fixed a problem where changing wireless security could reset previous wireless settings.
15. Modified 128-bit WEP to fill in all four keys when a passphrase is used to generate the key.
16. Fixed a problem where the log could show the hour as "24:xx".
17. Fixed a problem where firewall rules to block by schedule may not work with a range of WAN addresses.
18. Modified LAN settings to disallow the entry and report an error when trying to use the range 224.x.x.x - 255.x.x.x.
19. Fixed a problem where Connection Status could show the wrong IP address for the DHCP server.
20. Modified DNS proxy to support MX record lookups.
21. Fixed a problem where Remote Management could interfere with hosting web servers on LAN IP address when NAT was disabled.
Netgear's site has been slow all night so I've mirrored it here
Hi Rob
Have you used the beta version yet? If so does it work ok and does it increase the distance.
I tried your mirror link but it said 'tut 'tut' etc...
I've fixed the link - I forgot to put the "dg834_and_dg834g_V2_10_17.zip" bit in there.
I haven't upgraded to it yet. I believe the other admin on my board has done though. He has a standard ADSL connection with PN and doesn't do anything fancy on it however I have a permanent VPN tunnel and two when requireds working off mine so I'm a little scared to try the beta.
This v2.10.17 is rock solid on my DG834G Wink
http://portal.plus.net/central/forums/viewtopic.php?t=24650
LiamM
Installed fine on mine too. With no issues thus far.
I am now locking this thread in favour of the aforementioned one, linked above by morpheus124.
