New Limits - will i be able to have 1meg!
I know that the info on adsl gude.org isnt offical yet, but with the planned limits of 512k going up to 75db and 1meg going up to 60db, will i be able to get 1meg?
My current db is spot on 60db.
If so will it be a manual upgrade or just do it via the normal upgrade?
Simon
Hope i can, ive had adsl since 2001. My router shows the line at.
Downstream
Upstream
SNR Margin 13.3 19.0 dB
Line Attenuation 62.8 31.5 dB
Well, yes. If the limit is going to be 60dB, and your readings are 60dB, then it sounds OK to me.
Isp performed whoost test is 55db Cheesy so i should stand a good chance.
The leaked figures quoted are still provisional so may still change.
You probably have to wait a couple of months before the new figures are announced by BT. It is unlikely to happen until at least the MK extended reach trials are completed and this is planned for the end of sept 04.
There's hope after all then, I get around 47db at the moment, so I may yet be able to get a 1MB line. Cheesy
hmm now thats good news usually mine is 51-55 max but 58 in bad weather, this could be one for a mass mail once its live. Just hope the pipes in the future can take the extra strain
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
the_norris
gadgetboy - SNAP. Same signal here 47db. Hopefully 1Meg soon - yippy!
how do u find out this info (the Line Attenuation), i dont have a router Smiley
Send PlusNet a link:Contact Us ticket... they'll arrange a test for you to find out.
Thomas
keithcalder
Yes me too, I cant wait, sitting at 51db loss here. I feel the need, for more speed.. Smiley
Is anyone from PlusNet able to say when the new limits are likely to come into effect?
From September when the trials end.
it's more when BT says they will, probably due to work load as I wouldn't be a BT engineer this autum. As they'll be worked off their under paid rears with all the upgrades that will take place.
So fair warning to PN you will have a lot of people upgrading this Sept/Oct, so make sure you reading from the same script Wink
Apparently the new limits will come into effect during September:
http://bbs.adslguide.org.uk/showthreaded.php?Board=plusnet&Number=1337087
