New Drivers for Binatone modem
This post is for the "old" 2 light Binatone Modem that plus net used to supply.
Has anyone found newer drivers for it (other that the ones that came with it?)
Is your modem the binatone ADSL 500 (oh no thats the 3 light isnt it ).
Your going to have to tell what type of modem yours is (its type etc eg binatone ADSL................ )so then its easyer for me to help.
The following link has the latest drivers available:
ftp://customer:binatone@80.176.199.241/
Note: the new version directory is for the 3 light version.
The modem is the Binatone ADSL500 USB model with 2 lights.
The drivers on the above mentioned ftp site for this model are exactly the same as what came with the modem - are there nerwer ones?
Can I use the ADSL500 new model drivers?
That is the only place I have found drivers for the Binatone (apart from PlusNets page here).
You cannot use the New version drivers, it is not compatible with the 2 light version. The old drivers install the 2 light ADSL 500 as a dialup modem, the new drivers install the 3 light ADSL 500 as a network device (like a network card).
