New ADSL hardware
mitchell20
New ADSL hardware
I've already bought a Netgear DG834G ADSL router. My RFS date is 11th Feb. Will it cause any problems if I were to plug the router in now as I would like to start using the switch part of the router - even go as far as plugging the ADSL line into a phone socket with a splitter?
New ADSL hardware
No there will be no problems doing that
New ADSL hardware
I would think you can use the router part to network your PC's if you wish. There is nothing to stop you doing that, just disable the DSL side so it doesn't keep trying to connect (don't ask me how) and don't plug it into the phone socket/splitter until you are activated..
mitchell20
New ADSL hardware
thanks - just plugged it in and set up the PC's with auto-IP etc.
Everything appears to be OK Cheesy
