New 8 Mbps line running between 812.10kbps and 1800 kbps
My recent upgrade to 8 Mbps which costs me an extra £20 a month seems to be running at the same speed as my 2Mbps one, actually that's not entirely fair, it's running faster, as my 2Mbps line rarely ran faster than 512kbps.
Wouldn't mind the other 6Mbps of my bandwidth.
According to the spec, my router supports 8Mbps so something's wrong somewhere.
if your still within the 1st 10days of your connection then bt will be checking and testing your line to work out the best speed for you, after 10days they will settle on the best speed
Check to see if your sync speed is changing as that would indicate either the exchange is testing your connection or there may be a problem with it trying to sync.
Also while the exchange may be 8Mbs enabled, your line condition will untimately determin the maximum speed which may be a lot lower. Also BT state that during busy periods, you may not actually get more than a 2Mbs speed due to contention.
Fixes: 8
lonefox - which exchange are you on?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
You might not be on an exchange capable of getting 8mb yet. Plusnet have advertised this product for months as it has higher bandwidth allowances. If you are nto capable of this speed then it will be activated on your account when your exchange is enabled at that speed.
Upgrading to the broadband premier upto 8Mbs product will not get you 8Mbs speeds unless your exchange is one of the 55 currently undergoing trials of the 8Mbs / MaxDSL connection. If you exchange is not one of the 55, then your speeds will still be 2Mbs.
It would appear that my exchange isn't enabled for 8Meg, I guess I'll have to wait a little longer then.
You may have to wait until April, and possibly longer depending on BT's upgrade plan.
You could save yourself a bunch of money by going back to the product you were on previously and then upgrade to the higher speed when you know your exchange is upgraded. You also don't know if your line will actually run any faster so you may end up paying for a service you could never have got. The downgrade will cost you £14.99 but that would be saved within a month of lower monthly payments.
