Networking my ADSL connection
I want to network my two computers so they both have ADSL access.
This is what i have so far:
PC running xp
PC running 98
Solwise SAR110 Router
3 network cards
Network cable
How would i set this up and do i need any more components to network both my pcs to use the ADSL. I want it so that one can work when the other pc is off.
Any help is greatly appreciated, thanx
1 REPLY
RE: Networking my ADSL connection
The only extra bit of kit you'll need here is an ethernet hub. You plug the router into the hub along with the other PCs via network cables, then the router will share out the connection amongst all the PCs via the hub.
You can get them with 4 ports and above, and they are about £20 upwards.
Hope this helps!
Regards,
Richard
| Richard Allen................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd.........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
