Networking - DHCP, ADSL Router
Cool Cool
Hi there
Want to achieve 2 things :-
1.Network based on DHCP
2.Allowing internet access for 2 pc's.
Situration
Network
1.Server-win2000 server
2.client-win200 pro
Internet Access
1.ADSL connection - via client.
Other
1.SQL Server 2000 on Server
I'm a newie to networks - Access\SQL developer.
Qn1:-What is the best solution to this ?
i.e. buying ADSL Router
Was looking at NetGear DG834
http://www.netgear.co.uk/html/pdfs/dg834.pdf
Qn2:-Is it easy to set-up ?
Further Information:-
Currently I have a KVM Switch - 1 monitor, but 2 mouses + keyboards.
Any advice most welcomed...
ImraneA
[list=1]
  • Yes. The DG834 looks like a promising product. Do you plan on using a wireless connection for one (or both) of the PCs?
  • Yes. Assuming the DG834 will have a user interface similar to the earlier DG8x4 routers, then it should be possible to be up and running within minutes, simply by "plugging in" the standard ADSL settings on the configuration screens.[/listShocked]
  • N/A
    Thanks for comment..
    1."Yes. The DG834 looks like a promising product. Do you plan on using a wireless connection for one (or both) of the PCs? " - decided not to get wireless version of this product - need to upgrade my network cards to do that. Both be cabled.
    2."Yes. Assuming the DG834 will have a user interface similar to the earlier DG8x4 routers, then it should be possible to be up and running within minutes, simply by "plugging in" the standard ADSL settings on the configuration screens." - good
