Network or switch computers?
I have a PC that is connected to Plusnet via Dynamode USB modem to Broadband connection all working well. I have recently purchased a Sony Vaio laptop. How difficult would it be to link the two? (both on Win XP) Are we talking network?
Alternatively, could I just connect my laptop to the modem for internet access & temporarily disconnect the PC?
Any advise appreciated.
Thanks, Geoff
What your will be doing is running "Internet Connection Sharing". This is a type of network. Both PC's will net to have a network cards and be connected by a crossover cable. The machine to which the modem is connected must always be on for the other machine to connect.
Then you can install the relevent protocols
http://www.microsoft.com/windowsxp/pro/using/howto/networking/ics.asp
There are lots of overviews and tutorials on the net for Internet Connection Sharing, just type it into a search engine.
Of course, you could also do as you say, and simply swap the modem form one PC to the other.
Or use a router and connect either machine independently or both simultaneously.
Thanks for the prompt replies.
I will try option 1
