Network Time Server
Network Time Server
My Conexant based ADSL router thinks its is back in the 70's as the clock has not been set. The only way I can see of setting it is to amend one of the factory config files with details of a time server.
Does Plus.Net run a time server that customers can use ? If not, does W2K Pro support NTP and if so where is this configured ?
Many thanks,
James
Network Time Server
PlusNet have two NTP servers. ntp.plus.net and ntp2.plus.net
Network Time Server
best to use the second aka the second DNS server its more likely to be working.
BTW if its a Origo branded router theres a new firmware for it that has editable SNTP settings
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Network Time Server
Many thanks for both replies. FWIW this device is an unbranded (actually Mentor) Wireless 4 Port Router known to be based on a Conexant chipset. Great price and seems to work but the importers are not interested in supporting users and I have not found any source of new Firmware. Closest I have found is for a 4 Port ADSL router but I am reluctant to use this firmware as it may break the 802.11 Wireless Access Point functionality.
James
mssystems
Network Time Server
FYI: Manchester University run public access NTP servers at
ntp2a.mcc.ac.uk and ntp2b.mcc.ac.uk
For support of your Connexant router try
www.adsltech.com
and
www.origo2000.com
This is for the Origo brand but it may well be the same as your Mentor. I have used the Origo firmware on other Conexant unbranded routers (not wireless though). If it physically looks the same it probably is the same. DO NOT BLAME ME IF YOU MESS UP YOUR ROUTER.
BTW: Does the wireless router have the same security hole as the wired version? Telnet [external_ip_address] 254
Regards
Matt
www.mssystems.co.uk
Network Time Server
Regards
Matt
www.mssystems.co.uk
The new firmware for the 8100-8400 released 2 days ago fixes it, no idea for the wireless. But I still add those ports to block them, as I see this as a RC Firmware as it isn't a packaged firmware file. Its just a zip you manually load in to your router.
One good bit of info supposedly port range mapping is due end of this month or as the well forums techs says in 3 months if there end of the month definition lives true to form. to balance that the bad is no mention of the SPI firewall.
