Network Neigbourhood.
Hello, i have my computers networked. And on one of them (98se) network neighbourhood is not on the desktop and i cannot find it.
Does anyone have any suggestions?
Can i re-install it?
Thanks in advance.
The quickest way normaly to do this, is to remove all the drivers for your network card, both via the network control panel and device manager.
Reboot the system, and re-install the drivers.
This will usualy cure the rpoblem.
Alternativly, download and try Tweak UI.
I've already tried the tweakUI thing, didn't work.
I may just find myself a copy of XP, then it will be 10 times easier, won't it?
I managed to network 2 XP machines with 1 98se machine no problem.
In XP, I setup the network using the "add new network connection" wizard from "Network Connections". When this was done, it gave me the option to make a floppy which I could use on any other Windows machine [it installed core files needed, etc.].
Worked a treat! Smiley
