Netmeeting AR11 router
Has anyone got video working using netmeeting with an AR11 router firmware 2.6k supplied by Plusnet?
I'm forgetting what my dad looks like....
(OO)
RE: Netmeeting AR11 router
Hi Lee
I dont think its netmeeting, rather aceex. Anywayyou can use the DMZ option.
Cheers
Lyndon
Doh! You write netmeeting I read netgear Wink
BoneMan
> Has anyone got video working using netmeeting with an AR11 router firmware 2.6k supplied by Plusnet?<
Lee,
Usually you can only get this to work *if* you only have one PC *and* you can set your router into non-NAT mode. DMZ doesn't work because of the way that M$ have chosen to implement the software. I am not familiar with the AR11 so I don't know if you can set it non-NAT. Suggest you search the fora at www.adslguide.org.uk for more info.
Alternatively (spelt £££) you could change to a router that supports UPnP and your OS WinXP (if you're not using the latter already).
Good Luck!
BoneMan
> Lee,
> Good Luck!
> BoneMan
Thanx for all your replies. I have loads to try now.
So far, this is what I have tried individually and all together:
Port Forwarding
DMZ option
Enabling NAT
Once again - Thanx
(OO)
if you suss it out i would like a copy of your settings and ip adresses u used and ports you opened so i can implement it on mine as i have the same router
For now, here are the ports netmeeting uses:
389
522
1503
1720
1731
1024~65535 (H323 Video)
If you enable both TCP & UDP you'll be ok. Problem is Ar11 uses NAT which when Netmmeting sends out your video on a port of its' choice (1024~65535) video comes back on a different port (That's H323 for you)
(OO)
Did you get ths working with these ports? I dont understand. DMZ really means forward all.
> 389
> 522
> 1503
> 1720
> 1731
> (OO)
The ports I posted above are the ports netmeeting uses. Setting up Port forwarding is fine, my dad can see me, I just can't see him. It is because of the H323 protocol I think. My router knows what port I am forwarding video on and H323 tells the recipient pc what port to receive my video I am sending. Then H323 chooses another port to send the recipients video back to me on, the AR11 router won't let the video back in because of all intents and purposes, I did not send video out on that port.
I hope that made sense....
(OO)
It didnt really make sense to me. If you use DMZ then effect is all ports are forwarded is it not? So the router wont stop anything (udp/tcp) coming in?
> (OO)
This is taken from Boneman above:
Lee,
ie Microsoft
(OO)
