Netgear router DG814
If you have this router and it goes off-line, at the back is a small hole, insert a pen and hold in for 20 secs. Fixed.
Moderators note (John) Topic moved to a more apt forum.
Oh you mean the factory reset button...
So you mean "Not Fixed" then, 'cos it's thrown away your configuration and gone back to the factory default?
I have had no problems since.
it will probably work well provided you have remembered all your settings first Smiley
the DG814 manual doesn't say how to use that button, it merely mentions its existence.
Darn! Thanks for reminding me.. Must back up my configuration! Then I could restore it so it would be fixed. Wink
But surely that defeats the point of a factory reset? Erasing all your settings and starting fresh, and then just loading the settings back on?
Itteration is such a rewarding experience... Wink
