Netgear dg834Gt - can't send email - help please
canary2211
Can you help please?
Installed Netgear DG834GT wireless - easy - work really well - execpt when I send email from Outlook I get a message that says "connection to server interrupted" Also I had to go back to simple modem to post this message
Strangly a test email sent from Outlook email account test wizard works fine.
Any ideas?
Firewall? Or email settings?
Outlook is set to "Connect via LAN" and not "Connect via phone line via modem" - is that right?
Thanks!
1 REPLY
Looks like your wireless connection is dropping out. How far are you from the routerHuh
If you close just try the cable connection instead and see what happens.
