Netgear DM602UK ADSL Modem/Router... will it work
Hello Cheesy
Is anyone using this http://www.amazon.co.uk/exec/obidos/ASIN/B00008XYIE/qid=1064266329/sr=2-1/ref=sr_2_3_1/202-8155916-9... :?:
I plan to share my plus net adsl connection between a Desktop running XP Home Edition and A Laptop runing XP Pro. The Laptop will only be connected occasionally.
If the above device is no good please can you advise on a suitable device.
1 REPLY
This is a basic modem for use on one computer, it has a USB &
ethernet socket but it's not clear if you'll be able to use 2 computers at the same time. ie, one on usb & one on ethernet ( I know this is possible with an Origo unit) so you'd best find out before you purchase.
If your planning to go wireless with the laptop you'll need to buy a
wireless capable router to add to this, if not then your best bet might be the DG814 combined Modem/Router.
