Netgear DM602 Router - Configuration problems
I can log onto the DM602 (via http:/192.168.0.1). The configuration screen shows but everytime I try to apply any sort of configuration change I get a "Fails to perform specified action..." Has anyone else seen this? Any suggestions?
I don't have a DM602 but my impression from some other people here is it can be a bit of a pig to configure, the main stumbling block being whether you have it in "Ethernet" or "USB" mode. Personally, I'd be inclined to reset it to factory defaults, leave it disconnected for an hour or so, and then try again. If you're using Ethernet, make sure you have it in the right mode of operation.
Problem solved
Shockedops: It turns out it is important to switch off your PC firewall prior to configuring the router (I knew that!). Once this was switched off the router configured, rebooted and connected without problem.
