Netgear DG843 Email Subject Line
My DG834 refuses to write the date in the subject line of the emails it sends to me. I get this:
Netgear Security Log [fb:1c:3d]
This is the 3rd DG834 I've had, and the previous have done the same. There's nothing documented about it on the Netgear site and Google yealds no results either. Firmware updates do nothing to help. Dates and times specified within the body of the mails are fine so the problem isn't connected with the time server it uses, but with the script that send the mail.
I'm not looking for an answer, I'm just interested in knowing if anyone else has this too.
Sammi
Yep mine does the same, not sure what it means.
Mine doesn't do it either, although I wasn't aware that it was supposed to.
My doesn't bother sending me an email. At least with the latest firmware the logs show the correct time now.
Whether it sends e-mails, is purely down to the settings on the router. The router will update the time and date, once a week, normally sunday.
I'm still trying to find out what the text means, someone did tell me once but I can't remember
