Netgear DG834G V3
Netgear DG834G V3
Hi was wondering if anyone can tell me how i find out if interleaving is on or not on this router
Isitme
Netgear DG834G V3
Scroll down this page till you get to your router, then click to expand it. You will find all the info you want there-
http://www.kitz.co.uk/adsl/frogstats.htm
Netgear DG834G V3
or just download routerstats from here and it will tell you. You will need to enable the telnet connection feature of it.
