Netgear DG814
Netgear DG814
Will this router work on PlusNet network..I have tried Auto-Setup and manually
add the PlusNet DNS server address 212.159.13.49...212.159.13.50..no joy....any suggestHuh?
Netgear DG814
My DG814 worked faultlessly. No problems whatsoever. My DG834 is just the same!
Netgear DG814
Same here. Just used auto-setup and entered my ADSL login details. IP and DNS are set automatically.
Are you sure your using the correct login/password. It's not the same as the portal login. It will be username@plusdsl.net or username@plus.net and your normal password. This is detailed in the connection settings -> connection details page (see under My account on the left).
