Netgear DG814 and MR314 question
I hope someone can help me that might have come across the same problem or use the same equipment. I am trying to set up my Netgear DG814 ADSL Modem to work with my Netgear MR314 Wireless router. So far I have only had sucess setting it up as ethernet and not connected to the wan port of the MR314. When the DG814 is connected to the wan port of the MR314 then do cannot connect to the internet and get no wan adress and I cant ping anything not even the DG814.
Any help here would be greatly appreciated.
1 REPLY
RE: Netgear DG814 and MR314 question
when you setup up the Router/Hub you have to give it two Ip address one for the lan and one for the wan, then you need to setup a static route that sends all internet traffic to the wan IP address, which will then be passed to your modem.
hope this helps.
Scott.
