Netgear DG814 & DMZ
Netgear DG814 & DMZ
I was just wondering if the netgear DG814 has DMZ feature built in? DMZ is where 1 lan machine can be exposed to the entire internet, also if you could show me a screenshot of where this feature is in the netgear WWW interface i'd be most appreciated.
Thank You
Netgear DG814 & DMZ
Yes it does have a dmz zone but I cant give you a screen shot. A review of the router is here
http://www.adslguide.org.uk/hardware/reviews/2002/q4/netgear-dg814.asp
Netgear DG814 & DMZ
Im thinking of buying this router but ive heard that if you switch a pc of that is connected to the router and leave it inactive alnight long for example, when the computer boots up again and trys to access the internet it doesn't work and the router has to be rebooted to gain net access again? does this really happen? ive also heard summat about the clock!!
Cheers
Netgear DG814 & DMZ
Yes there is a setting in the router that needs to be set to zero (Idle timeout I think)
Once this has bee adjusted it should stay up for ever and a day Cool
Boundey
Netgear DG814 & DMZ
lol please stress the word SHOULD but with my dg814 it falls on its arse everyday, and thats the 2nd one i've had!!!
There something up somewhere and no one is putting their hands up to it Sad
Netgear DG814 & DMZ
my DG814 is fine..
Idle Timeout of 0
Current uptime of 18 hours (but I had to reboot it to change a setting the other day)
