Netgear DG632 Router question
On the configuration setting for this Modem.Router it asks for VCI and VPI settings
Below is part of the settings. Does anybody know what these VPI or VCI setting should be.?
Modem
ADSL Firmware Version 1.00.09.00
Modem Status Connected
Connect Mode T1413
Down Stream 1152kbps
Up Stream 288kbps
VPI 0
VCI 38
The values shown ther are correct (0 & 3Cool.
Thanks Phillip, it must have been a good guess by myself then as just entered these values but the connection seems to working well anyway.
BTW anybody who is thinking of getting this router don't bother as it is horrendous
to set up.
keithcalder
I have the wireless model, D834g and had it up and running in under 5 minutes, auto detect Isp and all settings. I thought the 834 was the same, oh well, we learn something new every day, the wireless jobbie is good though.
The Netgear DG834 is the same as the DG834G just without the Wireless capabilities. The DG632 is a seperate model and not from the DG834 Range.
http://www.netgear.com/products/details/DG834.php
http://www.netgear.com/products/details/DG632.php
See these pages for the two seperate wired Routers.
I have this router and it is a piece of the proverbial to set up by the way! That is if you can manage to type and IP address! LOL
Even the complicated stuff like port forwarding is a doddle; try setting it up on ciscos like i do!
Jake
