Netgear 834
Netgear 834
Looking at a netgear 834 for my 512BB service..
have 2 computers.. heavy MSN use and occasional P2P
2nd computer is in daughters bedroom so would like some control i.e. block certain websites..
is this a good choice?
or anyother surgestions..
Netgear 834
The netgear DG834 is a good choice and you can block sites or certain words with easy. You might want to go for the DG834G, the wireless version, if you want avoid the wires.
You can pick up a DG834 from Amazon for around £60.
I use one, so if you decide to go for it and want any help, then send me a PM.
Cheers,
Aaron
Netgear 834
Great choice, xpressmedia! I like you already!! :lol:
Netgear 834
Thanks for your help..
Just ordered from amazon.. £63 delivered..
I had found it prior to your advise about amazon for £68..
So thanks you saved me a fiver!
Delivered friday or monday.. so will see you then if i have problms..
thanks
Andy
Netgear 834
Wow! plug it in.. 5 mins of fidling! adn im on line!!!! how easy was that!
what about other computer!.... under 60 seconds!!!
no wonder netgear offer 24/7 support!! they are confident no one's gonna ring!!
Excellent product! thankyou all
Netgear 834
Well Done, xpressmedia! You're now a full member of a very exclusive club!! Wink
Netgear 834
Hmm..
Yes internet from both PC's setup with ease!!
Now how do i setup file and print sharing between the two?? cant find any info on this but?Huh
Netgear 834
I have a Netgear dg834 and have had nothing but problems - I can't access access any pages through IE. Recently Netgear remotely accessed my router and fixed the problem - but then i had to set my PC n Router to static IP's and the problems back. Netgear now say that it is a DNS name resolving problem and that all my settings are correct!!
Can you suggest anything this is driving me mad!! :shock:
Netgear 834
Dont know what to suggest! im new to this router stuff!
I found it a sinch to setup.. all automatic..
the only problem i had was sharing files across the network..
This turned out to be Internet security.. working fine now...
dont help you tho.. sorry
Netgear 834
What are the static IP addresses you are using?
Netgear 834
Have you reserved the addresses within the router and told it to start DCHP address from the address after your last static address?
Why have you decide to go for static address, just curious?
