NetGear834 Modem Router
just got 1 of these due to loosing sunc every now n then with me pci card, now ive set everything up and its working fine but i have a problem with not being able to connect to ICQ.
Anyone have any ideas on how i can get it to login to ICQ, i keep gettin ICQ Info Number: 0124 - Checked google for a search on that info number but without success, So any boffins on ere that can point me in the direction of a solution to this, all my friends i speak to use ICQ so i really need this to be sorted.
Thx
Chamone
I have the same router- try updating the firmware if you haven't already?
Have you got UPnP enabled on the router and installed on the OS (WinXP) ?
Ya UnPnP is ticket and checked and as for firmware im on the latest i guess..?
BTW whats the latest LOL
I have had ICQ working, but its kinda dropped again and gives the same error numner or info number shud i say!
This is really ticking me off now Grrrrrr Evil
Router: Firmware Version V1.04.01
Modem: ADSL Firmware Version 1.01.00.00
latest is 1.05.00. You can find it here.
I suspect ICQ does not use UPnP (very few apps do) so enabling it may not make any difference. Note: if Upnp is being used, the UPnP page on the router config will show entries in the portmap table.
I suspect you need to setup some port forwarding entried to get it to work. Try googling for the necessary ports you need to set rules for (I don;t use ICQ so can't help).
Right well finially got on it but im unable to send files (pics n other stuff) to friends, anyone any clo0's to what to do in the firewall settings to enable to to send files over icq..?
BTW what does the new updated firmware resolve?
Click on the link, then on the firmware version link and it tells you.
