Need to restart router
I set up the Solwise router yesterday, got onto the net, got various rules working as we have a vpn server and all seemed to be working ok.
however, if i either try to connect to the vpn then disconnect, or if i go into the solwise config pages, i then need to turn the router off then on again to get back onto the net.
does anyone have any ideas why this is happening, or do i have a faulty router?
thanks
RE: Need to restart router
> thanks
I've had a similar probelm with a Linksys router I've been trialing for my company. When disconnecting the VPN connection if I immediately try to go on the internet, the router drops the ADSL sync and reboot (albeit automatically).
I found that if I waited until windows had dropped the TCP active connection for the VPN - its kept alive for a while after you disconnect - then I had no problem. Check using Netstat command in a dos window when the connection is dropped and then try connecting to the internet.
To be honest, the best place to ask this might be the solwise forums at http://www.solwiseforum.co.uk - I'm sure that someone there will be able to offer assistance with regard to this.
Best Wishes,
Ian Wild
PlusNet Customer Support
thanks, it does seem to behave better if i don't reconnect quickly. the solwise forum hasn't been much help so far, the only answers i can find are too technically involved and noone seems to be able to give me anything in plain english!!
