Need recommendation for wireless setup
I`ve just signed on for plusnet and am awaiting line activation. I have a laptop with XP and want to use it wirelessly. I have no intention of setting up a network for other computers, just to use the laptop without wires but would like a good setup. What would you recommend ?
1 REPLY
Think you'd be well advised to have a wired option as well. You'll need it for setup/configuring. With wireless, making changes sometimes locks you out. Could be with the same laptop that you are using 'wirelessly'.
I recently setup a new network at home with a Belkin modem/router and after a really frustrating 2/3 weeks it's now working well. One thing I found is that you are best to use hardware all from same manufacturer and if you think that you might need tech support, then don't buy Linksys stuff!!!
