Need connection info to set up wireless modem/router
I was going to have a go at setting up my wireless network this evening, but whilst reading the instructions that came with the Belkin modem/router, I need the following info:-
VPI/VCI numbers if I am on PPPoE or PPPoA or
IP address & subnet , IP address for the ISP's gateway server & DNS.
I've looked at my connections on the portal and it says I am on a static IP address. It then gives the number as well as a Netmask number.
Please can someone tell me where I get all of the info that Belkin needs.
VPI = 0
VCI = 38
PPPoA
The rest you can set as get automatically or get dynamically or automatic, i.e. the router get's the info from PlusNet when it connects.
See http://www.plus.net/support/adsl/adsl_install_guide.shtml
Note, when petervaughan says VCI=30 he actually means VCI=38, see http://www.plus.net/support/adsl/adsl_install_guide.shtml.
Sorry to be picky Peter but...
Shockedops: corrected. Glad someone is awake.
