NTP - which IP to use ?
Does Plus Net have an NTP server for sending out time syncs ?
If not, does anyone know of a reliable one ?
Cheers
Steve :?:
Yes they do, however, how well in sync I am not sure.
The address is ntp.plus.net
Thanks. Wink
Lorian
Re: NTP - which IP to use ?
Cheers
Steve :?:
Yes they have one at ntp.plus.net
It's accurate (stratum 0 from linx).
Jc.
Both ntp1.plus.net and ntp2.plus.net are also available.
However ntp1.plus.net is the same as ntp.plus.net.
