NIC failure
NIC failure
Hello
Has anyone had a problem with windows not loading drivers correctly for there NIC?
This started out of the blue last night, am getting code 31 messages on 2 devices :
This is on windows xp service pack 2 professional edition
Binatone Adsl 500 modem
SIS 900 Ethernet Adapter
The following steps have been taken :
a) uninstalled the above devices and rebooted , hoping plug and play will work, this failed, just bringing up unknown device and showing the 2 above will yellow ! and the same error
b) uninstalled again and installed the binatone drivers, restarted same problem as above
c) installed a brand new nic, restarted and exactlly the same error on all 3 devices now
Ok thought it could be a registry problem, so used a registry fixing program, restarted and exactly the same problem happened
At this point all logic I had went out the window, so tried a system restore I created when first installed dsl, this went wrong big style and getting blue screens of death each time I restart the computer
So now it is the old format and re-install windows Sad
Just wondering if anyone has come across this before and did they manage to fix it?
darrenf
the_norris
NIC failure
Hi
Are these devices PCI card? I would try updating the chipset drivers.
Also I would remove the failed device via safe mode. - This way windows deleted the driver not just removing the device from the device manager.
Phil
okly dokly
Hello
Thanks for that, I did upgrade the SIS 900 ethernet drivers to the latest (it is an internal motherboard nic type thing) and this failed as well
The dsl modem is USB
Still working out why the USB modem needs a NIC anyway
oh well nuke and pave and a re-install of windows tonight
fun fun fun Smiley
NIC failure
A usb modem doesnt require a NIC, In fact it doesnt work with one.
All it requires is a usb port and the driver.
This is certainly true of the binatone adsl 500, I had one myself.
um strange
Hello
Whenever my binatone connects up it creates a LAN connection and needs a NIC to do this.
Not sure if this is right, but it has always done this since I have had it and has worked perfectly
Re-install of windows fixed the problem
darrenf
NIC failure
Your Binatone modem creates a Network Connection not a NIC.
You may be confusing the two.
1 is your physical connection (LAN) the other a peice of hardware.
ok
But the network connecton needs the nic?
I have tested this myself, by uninstalling the nic and just trying to use the USB connection
It fails everytime until I re-install the nic
It confuses me as well Smiley
Unless it is windows throwing a wobbly Smiley
oh well it is all working now anyway Smiley
NIC failure
That modem works perfectly happily on a system without a Network Interface Card or port so there must be something funny with your windows setup as a NIC is not needed.
