Mystery Outlook messages
When i open up outlook 2007 there are no messages in the outbox but it reports that it is sending 6 messages during the initial send and recieve.
I have spywar checkers on the system and up to date antivirus nothing is located by either. Can anyone suggest what's hapening.
cheers
A
What messages are in the out box? Did you import from another version which may have had some in the out box?
Is this just the first time you used it or every time you open it?
there were no messages in the out or sent box that was the mystery. I just opend outlook agin and it it didn't happen this time.
A
Dev
If you email from Word or Excel or some other program these will be sent when you open Outlook 2007.
yeah I had sent no email via this method either. it has all stopped now though.
A
maybe it was requesting a read receipt?
