My speed is slowing down
I have 2mb Premier broadband ( 20 / 1)
I have for most of the time hit speeds of
235 - 242 kbps and even when I had a new pc built
my speed stayed constant.
Recently I have had to disconnect my Router and all equipment
to do some redecorating. I am still to finish but can still set up my computer
and connect my router to surf the net.
I have found though that my speeds have dropped off a little with sites
I used before with no problem now downloading at between 190 and 225.
Some sites much less and others a little more.
I checked my speed with PLUSNET speedtester and it gives me a speed of 235 to 240 ( 1920 ) approx while 2 other speed testers inc ADSL GUIDE .org
display speeds ranging from 1575 to 1840 or 199 to 225.
PLUSNET support say as it falls between the criteria set by BT they are not interested. I on the other hand can not understand while my speeds have dropped off like this.
CAN ANYONE HELP?
