My connection or my computer?
for some reason since my connection went down for a few hours last week my computer or connection has decreased i play doac and quake 3 and in quake i have noticed i am lagging a lot more than i did when i had quite brilliant 35ping on certain servers but now even though it shows good ping times i am not maintaining them ingame. my system has not changed and i am really looking for some advice, i even get fluctuations of lag in daoc quite regularly now and the spikes are showing up on quake. Not sure what is the cause. can you help plusnet?? some sort of maintenance or something?
Have you checked your local exchange status? maybe BT has been doing so more, or the exchange has a contention issue?
Have you checked your machine for spyware, adware or trojans?
http://downloads.zdnet.co.uk/0,39025604,39060157s,00.htm
Very good spyware destoyer, actually got this off a link from help from this forum.
http://housecall.trendmicro.com/housecall/start_corp.asp
this is an online virus scanner, very good for trojans and malware, youd be surprised whats lurking on your pc.
Hope it helps
