My Results - very slow?
Traceroute Results: View Traceroutes
Traceroute Time (24 Hour): 18:03 to 18:39
Traceroute Duration: 36 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: Witham
Problem: Permanently Slow Data Transfer (Everything is slow)
Duration of Problem: Since installation
Minimum Speed Achieved On PlusNet Speedtest: 274.5 kbps
Maximum Speed Achieved On PlusNet Speedtest: 297 kbps
Average Speed Achieved On PlusNet Speedtest: 285.75 kbps
Account: ADSL Home (Self Install) - 512kb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: None
If i were you i would post a ticket to plusnet to get the problem investigated further. Also it could just be a line fault which it usually is most of the time. Can you give us more details such as what type of modem or router are you using.
Plusnet Staff
Plusnet Staff
If you raise this via Contact Us we can take a look into the problem and see what's causing it. If you go through the report a speed problem route theres a couple of other tests you can do which will help pinpoint the problem including a BT Speedtester.
I'd also recommend, if you haven't already, doing a full scan of your PC for virii and spyware as these can use up your bandwidth.
