My Pings are all to pot!
Dont know whats going on but recently my online gaming has ground to a halt. I dont do much downloading but i like my online gaming. My pings are terrible...my friends in Uk are usually about 30ms to me know they average 250+.
My set up has not changed in last 12months apart from being plagued by disconnects which has died down recently. Now the problem is that my ping has shot right up. Making gaming torture and me being the victim of kicks.Dont know if you can work anything out from my connection diagnostics cos its all french to me.DSL End User Diagnostic Program
Version 1.03.0005E
Saturday, September 17, 2005 23:12
- SYSTEM SUMMARY --------------------------------------------------
+ Driver Version: 1.12.0018Q-A (WanUsb)
+ OS Version: Windows XP Build: 2600
+ Number of Processors: 1
+ Processor Architecture: Intel
+ Processor Level: 15
+ Processor Model: 47
+ Processor Stepping: 0
+ Memory Usage: 16%
+ Total Physical Memory: 2095600 kB
+ Free Physical Memory: 1756108 kB
+ Total Virtual Memory: 2097024 kB
+ Free Virtual Memory: 2064032 kB
- TEST RESULTS ----------------------------------------------------
1. Interface Test Results:
INTERFACE TEST PASSED
2. Modem Test Results:
MODEM TEST PASSED
3. Line Test Results:
LINE TEST PASSED
4. Network Test Results:
DEVICE BT Voyager ADSL Modem is ALREADY CONNECTED
NETWORK TEST PASSED
- PROGRAM CONFIGURATION -------------------------------------------
INTERFACE TEST CONFIGURATION:
TEST: ENABLED
MODEM TEST CONFIGURATION:
TEST: ENABLED
EXPECTED DRIVER TYPE: WAN
VERIFY DIAL-UP ADDRESS: ENABLED
VPI: 0
VCI: 38
DATA MODE TIMEOUT: 120 seconds
LINE TEST CONFIGURATION:
TEST: ENABLED
VPI: 0
VCI: 38
NUMBER OF CELLS TO SEND: 5
OAM LOOPBACK TYPE: OAM F5 END TO END LOOPBACK
NETWORK TEST CONFIGURATION:
TEST: ENABLED
VPI: 0
VCI: 38
WIN9x DEVICE NAME: DSLWanUsb
WIN2K DEVICE NAME: BT Voyager ADSL Modem
- DIAL-UP NETWORKING CONNECTIONS SUMMARY --------------------------
Connection Summary: VALID ENTRY
Connection Name: BT Voyager ADSL Modem Connection
Device Type: isdn
Device Name: BT Voyager ADSL Modem
Use Country and Area Codes: DISABLED
Phone Number: 0,38
Use IP Header Compression: DISABLED
Use Default Gateway on Remote Network: ENABLED
Server Assigned IP Adderes: ENABLED
Server Assigned Name Server Addereses: ENABLED
NetBEUI Protocol: DISABLED
IPX Protocol: DISABLED
TCP/IP Protocol: ENABLED
Can you post a tracert or better still a WinMTR trace to one of your game servers that you are seeing high pings to?
See Servers: Ping & Traceroute for info on how to run them if you are not sure.
tracer route
This is what i got on gamespy arcade.
I usually host games but can no longer do this cos of my poor ping. In fact its making game play impossible the main reason for my internet connection. Cry
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| lo0-homesurf.pth-ag3.plus.net - 0 | 89 | 89 | 15 | 31 | 110 | 31 |
| ge0-0-0-405.pte-gw1.plus.net - 0 | 89 | 89 | 15 | 31 | 78 | 31 |
| 195.50.117.169 - 0 | 89 | 89 | 15 | 29 | 47 | 31 |
| ae-0-52.bbr2.London1.Level3.net - 0 | 89 | 89 | 15 | 29 | 63 | 32 |
| as-0-0.bbr1.LosAngeles1.Level3.net - 0 | 89 | 89 | 156 | 163 | 219 | 172 |
| ae-22-52.car2.LosAngeles1.Level3.net - 0 | 89 | 89 | 156 | 168 | 344 | 172 |
| unknown.Level3.net - 0 | 89 | 89 | 156 | 170 | 437 | 156 |
| border20.ge1-1-bbnet1.lax.pnap.net - 0 | 89 | 89 | 156 | 179 | 484 | 156 |
| intelenet-3.border20.lax.pnap.net - 0 | 89 | 89 | 156 | 172 | 188 | 171 |
| v8.core1.irv.intelenet.net - 0 | 89 | 88 | 156 | 176 | 188 | 187 |
| ign-accees1.core1.irv.intelenet.net - 0 | 89 | 88 | 171 | 181 | 547 | 172 |
| www.gamespyarcade.com - 0 | 88 | 88 | 156 | 178 | 453 | 172 |
|________________________________________________|______|______|______|______|______|______|
WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com
Average pings of 30ms within the plusnet network are good. They start to deteriorate once you leave plusnet (the fist hop to level 3 is still good) and go to the US. That is outside PlusNets control.
Do you have any UK based game servers you also have a problem with that you can post the ping times for?
