My Broadband Speed Test Results
origin = ADSLguide.org in uk
Results from your most recent broadband speed test recorded on 31 August 2002 at 11:52:34.
Your Connection
Direction Actual Speed True Speed
Downstream 72 Kbps (9.0 KB/sec) 82 Kbps (inc. overheads)
Upstream 240 Kbps (30.0 KB/sec) 276 Kbps (inc. overheads)
'Actual Speed' is the amount of useful data that your connection can transmit/receive per second. The 'True Speed' figure includes an approximation of data overheads (non-useful data).
My personal comment..
I am not exptect to see such speed from Broad Band..
If anyone can help with registry setting to improve the speed my ADSL up. I have installed cablenut 4.02 and run it but.. it seems that I am still slow... by the way, my OS is windows ME.
cheers
RE: My Broadband Speed Test Results
I've just tested at 432Kbps (54KBps) downstream & 239Kbps (29.9KBps) upstream, both actual speeds.
I run 98SE and the only ADSL-specific changes I've made were to increase the RWIN to 64240 and decrease the MRU to 1492. To adjust these and other registry settings painlessly, download DrTCP from <http://www.dslreports.com/front/drtcp.html>.
DSLReports.com has a wealth of information on tuning systems for optimum performance; it's well worth a couple of hour's reading.
HTH,
Slàinte!
Al
[ADSL Home self-install + Asus 6000EV]
changed
MTU=1492
Results from your most recent broadband speed test recorded on 31 August 2002 at 15:03:04.
Your Connection
Downstream 123 Kbps (15.4 KB/sec) 141 Kbps (inc. overheads)
Upstream 226 Kbps (28.3 KB/sec) 259 Kbps (inc. overheads)
changes RWIN = 64240
Your Connection
still something wrong...T_T
is there anyway that i can check what is wrong with my connection?
I got upstream 256kB/s and downstream 478kB/s.
MYU = 1500
RWIN = 513920
Try www.tweakmaster.com
> MYU = 1500
> RWIN = 513920
I've done a bit of experimenting this morning with RWIN sizes. I've tried 13068, 32120, 128480, 256960 and 513920 in addition to the 64240 I had set. With the highest setting I saw the fastest reported speed (453kbps/239kbps actual) but the 'slowest' was still a very acceptable 443kbps/221kbps. What's more there appeared to be no correlation between RWIN size and d/l speed, in that the next-best result was arrived at with an RWIN of 64240, followed by 13068.
Could using a router make RWIN on the PC less critical?
Slàinte!
Al
I'm getting the same kinda speeds.
Something is obviously wrong as the upload speeds are consistantly greater than the download speeds.
Apparently Plusnet are aware of this problem (I submitted a problem report) and are working to fix it. Might be worth submitting one too so they are aware of the extent of users that have the problem.
Al.
