My ADSL disconnectes when the phone rings
Any sugestions before I start changing phone lines.
Its not a pc problem as it happens on both pcs.
Im using a samsung usb modem
I assume its just a poor phone line but not sure how to check
BoneMan
RE: My ADSL disconnectes when the phone rings
Could be non-existent/non-working filters or possibly probs. with the phone wiring but I'm not an expert. Suggest you repost your prob. on a forum on http:/www.adslguide.org.uk/ where there a plenty of experienced folks used to solving this kind of thing.
BoneMan
> BoneMan
> hiya most likely to be your filter you should have the phone plugged in to the filter on one side and the pc on the other.i tried mine without a filter and the phone would not ring in yet at my old house it would ring but if there was a download running it would slowly drop in speed to nothing.do you have another phone and filter you can try,also try plugging the pc directly into a filter without using extension cables good luck stevie
fonejacker
Just so you have a third opinion :-)
This is normally the symptom of using ADSL without a micro-fitter installed. If you have one, and have tested it with a replacement filter, then please log this via contact us and we will raise the issue with BT.
Regards,
Ian Wild
PlusNet Customer Support
Many thanks for the above help.
Id already had a good mess with two microfilters before posting...but while looking for this post I found a possible answer...my old cordless phone may not be coompatible...just tried a fixed (ona a wire) phone and rang out while my adsl stayed connected...yippeee Shocked)
I will ow have to wait and see what happens with incoming calls, but it looks like this may solve the problem.
Next problem...what do I do with the old cordless phone...garden ornament perhaps ;o)
Jonathan Webb
