My ADSL connection problem
Traceroute Results: View Traceroute
Traceroute Time (24 Hour): 21:00 to 21:01
Traceroute Duration: 1 minutes
Traceroute Packet Size: 100 bytes
Exchange: Erdington
Problem: Permanently Slow Data Transfer (Everything is slow)
Duration of Problem: Please Select...
Minimum Speed Achieved On PlusNet Speedtest: 100 kbps
Maximum Speed Achieved On PlusNet Speedtest: 100 kbps
Average Speed Achieved On PlusNet Speedtest: 100 kbps
Account: ADSL Home (Self Install) - 2mb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: As discussed with someone on the phone I have been unable to complete the speed test as it just seems to time out.The numbers inputted are dummies. I had to manually run \"tracert\" from the dos prompt so have been unable to give uou traceroute packet size etc...
holdtight
there have been some connection problems today, see service status
try rebooting everything inc router or modem and see if it does the trick
sometimes thats all it takes
I wish it was just as simple as that but it appears to be more of a problem unfortunately.
I've sent a ticket to tech support..
