Multiplexing Method
Boundey
Multiplexing Method
right dead quick answer needed for this one is possible please...
i have the DG814 - Having a lot of problems with it at the mo so i'm going through all my configuration with a fine tooth comb at the mo and came across...
Multiplexing Method
What should it be set to?
LLC Based
or
VC Based
?Huh
1 REPLY
Multiplexing Method
A quick look in the Help & Support section of the portal tells you it's VC based. Smiley
Thomas
