Multiple Email boxes
Hi, sorry if this has been done to death but I couldnt find anything relevent on the search function.
My basic setup is PC with Belkin Wireless router and a laptop, with wireless connectivity for sharing the Internet, which my wife uses.
I have my own domain name hosted by Plusnet and use this as my email address on the lines of myfirstname@mydomainname.co.uk. My wife also uses herfirstname@mydomainname.co.uk. What I want to do is to be able to download only emails directed to me and not ones to my wife and vice-versa. It is such a pain to have to forward my wifes emails everytime I check my mail.
I thought it was possible and plus net seems to allow multiple mailboxes but I dont think this is the same thing.
Any help would be really appreciated.
Steve
Under email settings in your Account links, create a mailbox for you and your wife and allcoate a password for the mailboxes.
In your mail client set up an account for each of you using the format username+mailbox name and enter the passwords. All other settings are as normal.
Each of you then get you own seperate emails to wife@mydomain.co.uk or husband@mydomain.co.uk.
Hope that helps.
On the left, Click Email settings -> Configure Mailboxes and create 2 new mailboxes yourfirstname and herfirstname.
You on your email client, setup an account to collect mail from the yourfirstname mailbox using login yourplusnetname+yourfirstname and the password you assigned when you created the mailbox. Your wife then does the same on her email cleint using login yourplusnetname+herfirstname and the password you setup for that mailbox.
You can also collect all mail from your default mailbox using your portal login/password as you do currently.
See the the following help page: http://www.plus.net/support/email/email_settings/Mailboxes.shtml
Thanks for the info guys, I will give it a go this weekend . I am so busy trying to sort out my Gallery probs on the new server at the moment :shock:
Steve
Done & Dusted
Well my new mailboxes are up and working so a big thank you to those who helped.
Still not sorted out my new cgi site yet though Sad
