More Connection problems
Hi
After some problems with BT getyting confused when I moved house delaying things for over a month I've finally got ADSL enabled on my line but now I'm having problems establishing a connection. I've got a Dynamode A220 ADSL PCI Modem installed and it appears to be working ok but I can't establish a connection in dial up networking.
Can any one help with the DUN properties settings I should be using please? and should the DNS server settings be entered manually?
Any help gratefully received,
cheers
Bill Divers
RE: More Connection problems
What error message are you getting??
Occasionally 650 and occasionally 645 !!
> Hi,
Sorry if it sounds obvious but make sure you are entering yourusername@plusdsl.net in the user name field, type in 00000 for the number to dial. It's weird that your pci modem hasn't made a dun for you, mine did. Oh yeah, in dun properties, make sure isdn channel is ticked, not 56k modem.
Let us know how it goes
Thanks for the reply,
Still relying on 0845 for net access; tech support say there is a fault of some sort at their end which means I can't establish a DUN connection...and so keep getting error 645.
I'm still waiting for them to fix it.......
cheers
Bill
