Moment of Light Relief
If you can't solve the problem, at least give the customer a laugh. Direct quote (no editing) ......
2002-11-21
19:46:53 Comment By: You
I can now definitely state that rebooting has no effect. The problem is that although connected, the data transfer rate slows right down over a period of around 10 secs to a rate of bytes/minute - or effectively nil. I've effectively have no service all day today. Open
2002-11-22
03:20:20 Comment By: Mike Jianikos
Customer Support Centre Dear Customer
I beleive the problems that you are having are related to faulty spliters. I will pass this onto the technical team for clarification of this.
Regards,
Mike Jianikos
Internal,
User gets connected, if plugged straight into telephone socket - however when a filter is used it does not connect. Assigned
RE: Moment of Light Relief
> 2002-11-21
> 2002-11-22
> Regards,
> Mike Jianikos
> Internal,
LOL
Nick,
Are you a skier?
Chris
