Modem telling fibs
dekker
Modem telling fibs
Can anyone tell me why my modem reports my connection speed as 576.0kps
when the speed test tells me my 1meg regrade has apparently been applied.
How can i rectify this?
Modem telling fibs
What ADSL modem are you using?
Are you running the lastest drivers for it?
Does it have any diagnostics which can tell you the physical connection speeds?
dekker
Modem telling fibs
Modem is Dynamode A360 external USB.
Supplied by Plusnet.
Drivers are up to date.
Running WinXP home sr1.
In "Device Manager" it does not appear under Modems but is shown in Network Connections as A360 (Native ATM Mode).
Re: Modem telling fibs
No, it is not "telling fibs"as you put it.
I have the same modem and it always shows connection speed as 576.0Kps.
IF you have a 512 connection then it should show as that, if you have an active 1Mb connection then it should show as 1Mb.
So something is up if you have an active 1Mb account.
dekker
Modem telling fibs
Yep i definitely have a 1Meg connection, last speed test = 955
Yep something is definitley "up" Smiley
Modem telling fibs
It could be a bug in the driver software, try uninstalling it and re-installing it.
It does seem a little strange, but unless it affects your connection in anyway I wouldn't be overly worried.
Modem telling fibs
i just have the 512 connection and a lot of times after I uninstall anything of defrag then when I reboot it says my connection speed is 1Mb and downloading/surfing is twice as fast..................
Modem telling fibs
I have the same modem and im on 1mb and it connects at 1.1mb Cheesy
painswck
Modem telling fibs
576 is the line speed for a 512 connection. Nothing wrong with your driver software. most modems/routers will report this. In the same way they will normally report 288 in the other direction.
Roland
dekker
Modem telling fibs
Thanks everyone for your replies, my connection is fine and dandy, no problems.
Its just that I had been clicking on the systray connection icon and seeing 576 and grumbling at the delay in my upgrade, when for several days I had in fact been upgraded to 1Meg.
Not having done any downloading I hadn't noticed the difference. :roll:
dekker
Modem telling fibs
Totally sorted now,reinstalled driver as suggested by Gadgetboy, modem now says 1.1Bps.
Thanks a lot. Cheesy
