Modem supply problems
It was mentioned in the PN newsgroups that there are problems with the supply of ADSL modems.
What exactly is the issue, and what's happening? It gets annoying when your FRIACO dialup stops working, but you can't use ADSL because PN haven't dispatched the hardware to use it...
I think they switched suppliers from ebuyer to some other firm. Apparently the switch wasn't too clean - that might be it.
Good to see someone else on at 4am Cheesy
There is also a small issue, where the SAR110 router is being shipped with a 3COM manual, which is 0% related.
Other than that, there have been no frustrations made here receintly
