Modem need to be plugged in master socket?
Hey all wonder if any of you can give a little advice.
The current setup I have at home is one PSTN line for voice calls (now got ADSL on it) and a 2nd line for my old 56k modem internet.
Well I'm waiting for the hardware, I need to connect to the Internet upstairs in my bedroom where the computer is. However we didn't order broadband on the 2nd line (so we can get rid of it) - I wondering, if its ok if you link a extenstion from the master socket (on the first line) and reconnect to the lines we have running upstairs (the old exisiting 2nd line) ADSL won't have a problem with that will it when you plug the modem in there?
Reply if you can't understand!
Thanks Matt
1 REPLY
It doesn't matter if you use the master or an extension socket.
You can use your line as a normal phone line (eg for voice, fax, or even a traditional analogue modem) at the same time as using your ADSL modem, so you may decide you no longer need two lines.
For further help and advice, see the ADSL: Wiring and Filters Tutorial.
