Modem and attenuation question
These are my readings off my modem
local/remote attenuation 63.5/31.5dB
snr margin 12.5dB
I know these readinds are pretty bad, the thing is I've had my modem now for 3 years and need to get another one anyway along with another filter, would a new modem improve these readings, and is there any difference (performance wise) between microfilters and the faceplates with intergrated adsl points that go over the master socket or do they perform just as goos as each other. :?:
1 REPLY
I doubt a new modem would improve the readings, you're still using the same line at the same distance from the exchange. I'm not sure about the faceplate however.
Owen
