Modem Disconnecting
Modem Disconnecting
I currently have a binatone adsl 500 modem and 1mb connection, which is set to always on yet when i start up my pc the only way to get the connection active is to unplug and then plug in my usb cable. Is there a solution for this small but annoying problem ?
Modem Disconnecting
Have you followed PlusNet's guide for setting up this modem at http://portal.plus.net/support/adsl/binatone_setup_guide_jan2004.shtml?
Tim
Modem Disconnecting
Followed the guide but it is still no different!
Modem Disconnecting
Have you installed the latest drivers for your modem? These can be downloaded from http://www.binatonebroadband.com/downloads/.
Tim
