Microfilters
Microfilters
My BT line has, apparently, been activated for ADSL and I have been billed accordingly. I have two internal lines, with a telephone on each. Will I need to buy two microfilters for each of the two sockets, or just one {for the socket I use for my computer)?
1 REPLY
RE: Microfilters
If they are two seperate lines then you will only need splitters on the line the ADSL is on. If they are the same line. Then you will of course need a splitter on both.
Kind regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| PlusNet Customer Support .......... for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
