Micro Filter Problems
I think I may be having some problems with my mircofilter; when I plug my filter in the quality of voice line goes down discernably - to such an extent that I can't ring out and get a "number not recognised" message.
When I plug just the telephone into the line all is fine.
I guess this sounds like a filter problem ? Anyone any clues ?
1 REPLY
RE: Micro Filter Problems
> Hi,
> Thanks
We had exactly the same issue, we had a BT engineer visit and confirm that the line was OK. He tested the microfilter and found that our filter was the problem, the line was fine when he used his. I suggest you swap the filter.
Cheers
