Message For PlusNet Support Re: Disconnections
Support,
Regarding the random disconnections, i only suffered a few while web browsing before thid week.
Tonight, i was streaming to live365.com @ 16kbps not much upstream, but kept losing sync or data with server, or kept disconnecting. this happened from 4pm - 11pm tonight.
I is so bad i just gave up.
Between this period i was disconnected from PlusNet and not just the actual exchange IP stream. IE loss of the data. i also got some packet loss, and drops.
I can provide you with the detailed log of tonight. which includes my OS and the exact times of the drops, and disconnections.
so that you know im not talking porkies.
It's a bit long, so sorry for this..
im just reporting a fault. maybe you can copy and paste this log into notepad and send to engineers.
LOG FILE.
Studio365-Live 2.2 (build 31)
Log file for 11/19/02 16:31:19, built on Jul 1 2002, 13:13:27
(11/19/02 16:31:19) Switching source to the External source : system mixer
(11/19/02 16:31:20) Starting Studio365-Live 2.2 on www.live365.com
(11/19/02 16:31:20) ISP Connection is T1/DSL/ISDN/Cable
(11/19/02 16:31:20) Your broadcast is 16000 BPS and aimed towards users with a 28.8K modem or better
(11/19/02 16:31:20) User : jasondolan, Win-NT 5.1, Service Pack 1
(11/19/02 16:31:20) 2390 mhz, GenuineIntel, x86 Family 15 Model 2 Stepping 4
(11/19/02 16:31:26) Toggling ON the broadcast server for jasondolan
(11/19/02 16:31:27) Broadcast server successfully switched ON
(11/19/02 16:31:2Cool Connection made with server, www.live365.com, port 20657
(11/19/02 16:31:2Cool Logging on to account for jasondolan
(11/19/02 16:31:2Cool Logged on successfully
(11/19/02 18:40:15) Line down, attempting to reconnect. The line has dropped 0 times.
(11/19/02 18:40:36) Connection made with server, www.live365.com, port 20657
(11/19/02 18:40:36) Logging on to account for jasondolan
(11/19/02 18:40:36) Nanocaster log-in failed, no response from the server.
(11/19/02 18:40:36) Re-connect failed
(11/19/02 18:40:46) Line down, attempting to reconnect. The line has dropped 0 times.
(11/19/02 18:40:46) Connection made with server, www.live365.com, port 20657
(11/19/02 18:40:46) Logging on to account for jasondolan
(11/19/02 18:40:47) Logged on successfully
(11/19/02 18:40:47) Re-connected successfully!
(11/19/02 21:15:53) Line down, attempting to reconnect. The line has dropped 1 times.
(11/19/02 21:16:10) XML Error on line 9, position 12 in "file:///C:/DOCUME~1/Jason/LOCALS~1/Temp/xml143.xml".
(11/19/02 21:16:14) Connection made with server, www.live365.com, port 20657
(11/19/02 21:16:14) Logging on to account for jasondolan
(11/19/02 21:16:14) Nanocaster log-in failed, no response from the server.
(11/19/02 21:16:14) Re-connect failed
(11/19/02 21:16:24) Line down, attempting to reconnect. The line has dropped 1 times.
(11/19/02 21:16:24) Connection made with server, www.live365.com, port 20657
(11/19/02 21:16:24) Logging on to account for jasondolan
(11/19/02 21:16:26) Logged on successfully
(11/19/02 21:16:27) Re-connected successfully!
(11/19/02 22:22:26) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:22:26) Connection made with server, www.live365.com, port 20657
(11/19/02 22:22:26) Logging on to account for jasondolan
(11/19/02 22:22:26) Nanocaster log-in failed, no response from the server.
(11/19/02 22:22:26) Re-connect failed
(11/19/02 22:22:36) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:22:36) Connection made with server, www.live365.com, port 20657
(11/19/02 22:22:36) Logging on to account for jasondolan
(11/19/02 22:22:36) Nanocaster log-in failed, no response from the server.
(11/19/02 22:22:36) Re-connect failed
(11/19/02 22:22:46) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:22:46) Connection made with server, www.live365.com, port 20657
(11/19/02 22:22:46) Logging on to account for jasondolan
(11/19/02 22:22:46) Nanocaster log-in failed, no response from the server.
(11/19/02 22:22:46) Re-connect failed
(11/19/02 22:22:56) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:22:56) Connection made with server, www.live365.com, port 20657
(11/19/02 22:22:56) Logging on to account for jasondolan
(11/19/02 22:22:56) Nanocaster log-in failed, no response from the server.
(11/19/02 22:22:56) Re-connect failed
(11/19/02 22:23:06) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:23:06) Connection made with server, www.live365.com, port 20657
(11/19/02 22:23:06) Logging on to account for jasondolan
(11/19/02 22:23:06) Nanocaster log-in failed, no response from the server.
(11/19/02 22:23:06) Re-connect failed
(11/19/02 22:23:16) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:23:16) Connection made with server, www.live365.com, port 20657
(11/19/02 22:23:16) Logging on to account for jasondolan
(11/19/02 22:23:16) Nanocaster log-in failed, no response from the server.
(11/19/02 22:23:16) Re-connect failed
(11/19/02 22:23:26) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:23:26) Connection made with server, www.live365.com, port 20657
(11/19/02 22:23:26) Logging on to account for jasondolan
(11/19/02 22:23:26) Nanocaster log-in failed, no response from the server.
(11/19/02 22:23:26) Re-connect failed
(11/19/02 22:23:36) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:23:36) Connection made with server, www.live365.com, port 20657
(11/19/02 22:23:36) Logging on to account for jasondolan
(11/19/02 22:23:36) Nanocaster log-in failed, no response from the server.
(11/19/02 22:23:36) Re-connect failed
(11/19/02 22:23:46) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:23:46) Connection made with server, www.live365.com, port 20657
(11/19/02 22:23:46) Logging on to account for jasondolan
(11/19/02 22:23:46) Nanocaster log-in failed, no response from the server.
(11/19/02 22:23:46) Re-connect failed
(11/19/02 22:23:56) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:23:56) Connection made with server, www.live365.com, port 20657
(11/19/02 22:23:56) Logging on to account for jasondolan
(11/19/02 22:23:56) Nanocaster log-in failed, no response from the server.
(11/19/02 22:23:56) Re-connect failed
(11/19/02 22:24:06) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:24:06) Connection made with server, www.live365.com, port 20657
(11/19/02 22:24:06) Logging on to account for jasondolan
(11/19/02 22:24:06) Nanocaster log-in failed, no response from the server.
(11/19/02 22:24:06) Re-connect failed
(11/19/02 22:24:16) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:24:16) Connection made with server, www.live365.com, port 20657
(11/19/02 22:24:16) Logging on to account for jasondolan
(11/19/02 22:24:16) Nanocaster log-in failed, no response from the server.
(11/19/02 22:24:16) Re-connect failed
(11/19/02 22:24:26) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:24:26) Connection made with server, www.live365.com, port 20657
(11/19/02 22:24:26) Logging on to account for jasondolan
(11/19/02 22:24:26) Nanocaster log-in failed, no response from the server.
(11/19/02 22:24:26) Re-connect failed
(11/19/02 22:24:36) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:24:36) Connection made with server, www.live365.com, port 20657
(11/19/02 22:24:36) Logging on to account for jasondolan
(11/19/02 22:24:36) Nanocaster log-in failed, no response from the server.
(11/19/02 22:24:36) Re-connect failed
(11/19/02 22:24:46) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:24:46) Connection made with server, www.live365.com, port 20657
(11/19/02 22:24:46) Logging on to account for jasondolan
(11/19/02 22:24:46) Nanocaster log-in failed, no response from the server.
(11/19/02 22:24:46) Re-connect failed
(11/19/02 22:24:56) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:24:56) Connection made with server, www.live365.com, port 20657
(11/19/02 22:24:56) Logging on to account for jasondolan
(11/19/02 22:24:56) Nanocaster log-in failed, no response from the server.
(11/19/02 22:24:56) Re-connect failed
(11/19/02 22:25:06) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:25:06) Connection made with server, www.live365.com, port 20657
(11/19/02 22:25:06) Logging on to account for jasondolan
(11/19/02 22:25:06) Nanocaster log-in failed, no response from the server.
(11/19/02 22:25:06) Re-connect failed
(11/19/02 22:25:16) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:25:16) Connection made with server, www.live365.com, port 20657
(11/19/02 22:25:16) Logging on to account for jasondolan
(11/19/02 22:25:16) Nanocaster log-in failed, no response from the server.
(11/19/02 22:25:16) Re-connect failed
(11/19/02 22:25:26) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:25:26) Connection made with server, www.live365.com, port 20657
(11/19/02 22:25:26) Logging on to account for jasondolan
(11/19/02 22:25:26) Nanocaster log-in failed, no response from the server.
(11/19/02 22:25:26) Re-connect failed
(11/19/02 22:25:36) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:25:36) Connection made with server, www.live365.com, port 20657
(11/19/02 22:25:36) Logging on to account for jasondolan
(11/19/02 22:25:36) Nanocaster log-in failed, no response from the server.
(11/19/02 22:25:36) Re-connect failed
(11/19/02 22:25:46) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:25:46) Connection made with server, www.live365.com, port 20657
(11/19/02 22:25:46) Logging on to account for jasondolan
(11/19/02 22:25:46) Nanocaster log-in failed, no response from the server.
(11/19/02 22:25:46) Re-connect failed
(11/19/02 22:25:56) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:25:56) Connection made with server, www.live365.com, port 20657
(11/19/02 22:25:56) Logging on to account for jasondolan
(11/19/02 22:25:56) Nanocaster log-in failed, no response from the server.
(11/19/02 22:25:56) Re-connect failed
(11/19/02 22:26:06) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:26:06) Connection made with server, www.live365.com, port 20657
(11/19/02 22:26:06) Logging on to account for jasondolan
(11/19/02 22:26:06) Nanocaster log-in failed, no response from the server.
(11/19/02 22:26:06) Re-connect failed
(11/19/02 22:26:19) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:26:19) Connection made with server, www.live365.com, port 20657
(11/19/02 22:26:19) Logging on to account for jasondolan
(11/19/02 22:26:19) Nanocaster log-in failed, no response from the server.
(11/19/02 22:26:19) Re-connect failed
(11/19/02 22:26:29) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:26:29) Connection made with server, www.live365.com, port 20657
(11/19/02 22:26:29) Logging on to account for jasondolan
(11/19/02 22:26:29) Nanocaster log-in failed, no response from the server.
(11/19/02 22:26:29) Re-connect failed
(11/19/02 22:26:39) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:26:39) Connection made with server, www.live365.com, port 20657
(11/19/02 22:26:39) Logging on to account for jasondolan
(11/19/02 22:26:39) Nanocaster log-in failed, no response from the server.
(11/19/02 22:26:39) Re-connect failed
(11/19/02 22:26:49) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:26:49) Connection made with server, www.live365.com, port 20657
(11/19/02 22:26:49) Logging on to account for jasondolan
(11/19/02 22:26:49) Nanocaster log-in failed, no response from the server.
(11/19/02 22:26:49) Re-connect failed
(11/19/02 22:26:59) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:26:59) Connection made with server, www.live365.com, port 20657
(11/19/02 22:26:59) Logging on to account for jasondolan
(11/19/02 22:26:59) Nanocaster log-in failed, no response from the server.
(11/19/02 22:26:59) Re-connect failed
(11/19/02 22:27:09) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:27:09) Connection made with server, www.live365.com, port 20657
(11/19/02 22:27:09) Logging on to account for jasondolan
(11/19/02 22:27:09) Nanocaster log-in failed, no response from the server.
(11/19/02 22:27:09) Re-connect failed
(11/19/02 22:27:19) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:27:19) Connection made with server, www.live365.com, port 20657
(11/19/02 22:27:19) Logging on to account for jasondolan
(11/19/02 22:27:19) Nanocaster log-in failed, no response from the server.
(11/19/02 22:27:19) Re-connect failed
(11/19/02 22:27:29) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:27:29) Connection made with server, www.live365.com, port 20657
(11/19/02 22:27:29) Logging on to account for jasondolan
(11/19/02 22:27:29) Nanocaster log-in failed, no response from the server.
(11/19/02 22:27:29) Re-connect failed
(11/19/02 22:27:39) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:27:39) Connection made with server, www.live365.com, port 20657
(11/19/02 22:27:39) Logging on to account for jasondolan
(11/19/02 22:27:39) Nanocaster log-in failed, no response from the server.
(11/19/02 22:27:39) Re-connect failed
(11/19/02 22:27:49) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:27:49) Connection made with server, www.live365.com, port 20657
(11/19/02 22:27:49) Logging on to account for jasondolan
(11/19/02 22:27:49) Nanocaster log-in failed, no response from the server.
(11/19/02 22:27:49) Re-connect failed
(11/19/02 22:27:59) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:27:59) Connection made with server, www.live365.com, port 20657
(11/19/02 22:27:59) Logging on to account for jasondolan
(11/19/02 22:27:59) Nanocaster log-in failed, no response from the server.
(11/19/02 22:27:59) Re-connect failed
(11/19/02 22:28:09) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:28:09) Connection made with server, www.live365.com, port 20657
(11/19/02 22:28:09) Logging on to account for jasondolan
(11/19/02 22:28:09) Nanocaster log-in failed, no response from the server.
(11/19/02 22:28:09) Re-connect failed
(11/19/02 22:28:19) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:28:19) Connection made with server, www.live365.com, port 20657
(11/19/02 22:28:19) Logging on to account for jasondolan
(11/19/02 22:28:19) Nanocaster log-in failed, no response from the server.
(11/19/02 22:28:19) Re-connect failed
(11/19/02 22:28:29) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:28:29) Connection made with server, www.live365.com, port 20657
(11/19/02 22:28:29) Logging on to account for jasondolan
(11/19/02 22:28:29) Nanocaster log-in failed, no response from the server.
(11/19/02 22:28:29) Re-connect failed
(11/19/02 22:28:39) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:28:39) Connection made with server, www.live365.com, port 20657
(11/19/02 22:28:39) Logging on to account for jasondolan
(11/19/02 22:28:39) Nanocaster log-in failed, no response from the server.
(11/19/02 22:28:39) Re-connect failed
(11/19/02 22:28:49) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:28:49) Connection made with server, www.live365.com, port 20657
(11/19/02 22:28:49) Logging on to account for jasondolan
(11/19/02 22:28:49) Nanocaster log-in failed, no response from the server.
(11/19/02 22:28:49) Re-connect failed
(11/19/02 22:29:00) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:29:00) Connection made with server, www.live365.com, port 20657
(11/19/02 22:29:00) Logging on to account for jasondolan
(11/19/02 22:29:00) Nanocaster log-in failed, no response from the server.
(11/19/02 22:29:00) Re-connect failed
(11/19/02 22:29:10) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:29:10) Connection made with server, www.live365.com, port 20657
(11/19/02 22:29:10) Logging on to account for jasondolan
(11/19/02 22:29:10) Nanocaster log-in failed, no response from the server.
(11/19/02 22:29:10) Re-connect failed
(11/19/02 22:29:20) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:29:20) Connection made with server, www.live365.com, port 20657
(11/19/02 22:29:20) Logging on to account for jasondolan
(11/19/02 22:29:20) Nanocaster log-in failed, no response from the server.
(11/19/02 22:29:20) Re-connect failed
(11/19/02 22:29:30) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:29:30) Connection made with server, www.live365.com, port 20657
(11/19/02 22:29:30) Logging on to account for jasondolan
(11/19/02 22:29:30) Nanocaster log-in failed, no response from the server.
(11/19/02 22:29:30) Re-connect failed
(11/19/02 22:29:40) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:29:40) Connection made with server, www.live365.com, port 20657
(11/19/02 22:29:40) Logging on to account for jasondolan
(11/19/02 22:29:40) Nanocaster log-in failed, no response from the server.
(11/19/02 22:29:40) Re-connect failed
(11/19/02 22:29:50) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:29:50) Connection made with server, www.live365.com, port 20657
(11/19/02 22:29:50) Logging on to account for jasondolan
(11/19/02 22:29:50) Nanocaster log-in failed, no response from the server.
(11/19/02 22:29:50) Re-connect failed
(11/19/02 22:30:00) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:30:00) Connection made with server, www.live365.com, port 20657
(11/19/02 22:30:00) Logging on to account for jasondolan
(11/19/02 22:30:00) Nanocaster log-in failed, no response from the server.
(11/19/02 22:30:00) Re-connect failed
(11/19/02 22:30:12) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:30:12) Connection made with server, www.live365.com, port 20657
(11/19/02 22:30:12) Logging on to account for jasondolan
(11/19/02 22:30:12) Nanocaster log-in failed, no response from the server.
(11/19/02 22:30:12) Re-connect failed
(11/19/02 22:30:22) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:30:22) Connection made with server, www.live365.com, port 20657
(11/19/02 22:30:22) Logging on to account for jasondolan
(11/19/02 22:30:22) Nanocaster log-in failed, no response from the server.
(11/19/02 22:30:22) Re-connect failed
(11/19/02 22:30:32) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:30:32) Connection made with server, www.live365.com, port 20657
(11/19/02 22:30:32) Logging on to account for jasondolan
(11/19/02 22:30:32) Nanocaster log-in failed, no response from the server.
(11/19/02 22:30:32) Re-connect failed
(11/19/02 22:30:42) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:30:42) Connection made with server, www.live365.com, port 20657
(11/19/02 22:30:42) Logging on to account for jasondolan
(11/19/02 22:30:42) Nanocaster log-in failed, no response from the server.
(11/19/02 22:30:42) Re-connect failed
(11/19/02 22:30:52) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:30:52) Connection made with server, www.live365.com, port 20657
(11/19/02 22:30:52) Logging on to account for jasondolan
(11/19/02 22:30:52) Nanocaster log-in failed, no response from the server.
(11/19/02 22:30:52) Re-connect failed
(11/19/02 22:31:02) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:31:02) Connection made with server, www.live365.com, port 20657
(11/19/02 22:31:02) Logging on to account for jasondolan
(11/19/02 22:31:02) Nanocaster log-in failed, no response from the server.
(11/19/02 22:31:02) Re-connect failed
(11/19/02 22:31:12) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:31:12) Connection made with server, www.live365.com, port 20657
(11/19/02 22:31:12) Logging on to account for jasondolan
(11/19/02 22:31:12) Nanocaster log-in failed, no response from the server.
(11/19/02 22:31:12) Re-connect failed
(11/19/02 22:31:22) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:31:22) Connection made with server, www.live365.com, port 20657
(11/19/02 22:31:22) Logging on to account for jasondolan
(11/19/02 22:31:22) Nanocaster log-in failed, no response from the server.
(11/19/02 22:31:22) Re-connect failed
(11/19/02 22:31:32) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:31:32) Connection made with server, www.live365.com, port 20657
(11/19/02 22:31:32) Logging on to account for jasondolan
(11/19/02 22:31:32) Nanocaster log-in failed, no response from the server.
(11/19/02 22:31:32) Re-connect failed
(11/19/02 22:31:42) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:31:42) Connection made with server, www.live365.com, port 20657
(11/19/02 22:31:42) Logging on to account for jasondolan
(11/19/02 22:31:42) Nanocaster log-in failed, no response from the server.
(11/19/02 22:31:42) Re-connect failed
(11/19/02 22:31:52) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:31:52) Connection made with server, www.live365.com, port 20657
(11/19/02 22:31:52) Logging on to account for jasondolan
(11/19/02 22:31:52) Nanocaster log-in failed, no response from the server.
(11/19/02 22:31:52) Re-connect failed
(11/19/02 22:32:02) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:32:02) Connection made with server, www.live365.com, port 20657
(11/19/02 22:32:02) Logging on to account for jasondolan
(11/19/02 22:32:02) Nanocaster log-in failed, no response from the server.
(11/19/02 22:32:02) Re-connect failed
(11/19/02 22:32:12) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:32:12) Connection made with server, www.live365.com, port 20657
(11/19/02 22:32:12) Logging on to account for jasondolan
(11/19/02 22:32:12) Nanocaster log-in failed, no response from the server.
(11/19/02 22:32:12) Re-connect failed
(11/19/02 22:32:22) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:32:22) Connection made with server, www.live365.com, port 20657
(11/19/02 22:32:22) Logging on to account for jasondolan
(11/19/02 22:32:22) Nanocaster log-in failed, no response from the server.
(11/19/02 22:32:22) Re-connect failed
(11/19/02 22:32:33) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:32:33) Connection made with server, www.live365.com, port 20657
(11/19/02 22:32:33) Logging on to account for jasondolan
(11/19/02 22:32:33) Nanocaster log-in failed, no response from the server.
(11/19/02 22:32:33) Re-connect failed
(11/19/02 22:32:43) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:32:43) Connection made with server, www.live365.com, port 20657
(11/19/02 22:32:43) Logging on to account for jasondolan
(11/19/02 22:32:43) Nanocaster log-in failed, no response from the server.
(11/19/02 22:32:43) Re-connect failed
(11/19/02 22:32:53) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:32:53) Connection made with server, www.live365.com, port 20657
(11/19/02 22:32:53) Logging on to account for jasondolan
(11/19/02 22:32:53) Nanocaster log-in failed, no response from the server.
(11/19/02 22:32:53) Re-connect failed
(11/19/02 22:33:03) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:33:03) Connection made with server, www.live365.com, port 20657
(11/19/02 22:33:03) Logging on to account for jasondolan
(11/19/02 22:33:03) Nanocaster log-in failed, no response from the server.
(11/19/02 22:33:03) Re-connect failed
(11/19/02 22:33:13) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:33:13) Connection made with server, www.live365.com, port 20657
(11/19/02 22:33:13) Logging on to account for jasondolan
(11/19/02 22:33:13) Nanocaster log-in failed, no response from the server.
(11/19/02 22:33:13) Re-connect failed
(11/19/02 22:33:23) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:33:23) Connection made with server, www.live365.com, port 20657
(11/19/02 22:33:23) Logging on to account for jasondolan
(11/19/02 22:33:23) Nanocaster log-in failed, no response from the server.
(11/19/02 22:33:23) Re-connect failed
(11/19/02 22:33:33) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:33:33) Connection made with server, www.live365.com, port 20657
(11/19/02 22:33:33) Logging on to account for jasondolan
(11/19/02 22:33:33) Nanocaster log-in failed, no response from the server.
(11/19/02 22:33:33) Re-connect failed
(11/19/02 22:33:43) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:33:43) Connection made with server, www.live365.com, port 20657
(11/19/02 22:33:43) Logging on to account for jasondolan
(11/19/02 22:33:43) Nanocaster log-in failed, no response from the server.
(11/19/02 22:33:43) Re-connect failed
(11/19/02 22:33:53) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:33:53) Connection made with server, www.live365.com, port 20657
(11/19/02 22:33:53) Logging on to account for jasondolan
(11/19/02 22:33:53) Nanocaster log-in failed, no response from the server.
(11/19/02 22:33:53) Re-connect failed
(11/19/02 22:34:03) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:34:03) Connection made with server, www.live365.com, port 20657
(11/19/02 22:34:03) Logging on to account for jasondolan
(11/19/02 22:34:03) Nanocaster log-in failed, no response from the server.
(11/19/02 22:34:03) Re-connect failed
(11/19/02 22:34:13) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:34:13) Connection made with server, www.live365.com, port 20657
(11/19/02 22:34:13) Logging on to account for jasondolan
(11/19/02 22:34:13) Nanocaster log-in failed, no response from the server.
(11/19/02 22:34:13) Re-connect failed
(11/19/02 22:34:23) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:34:23) Connection made with server, www.live365.com, port 20657
(11/19/02 22:34:23) Logging on to account for jasondolan
(11/19/02 22:34:23) Nanocaster log-in failed, no response from the server.
(11/19/02 22:34:23) Re-connect failed
(11/19/02 22:34:33) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:34:33) Connection made with server, www.live365.com, port 20657
(11/19/02 22:34:33) Logging on to account for jasondolan
(11/19/02 22:34:33) Nanocaster log-in failed, no response from the server.
(11/19/02 22:34:33) Re-connect failed
(11/19/02 22:34:43) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:34:43) Connection made with server, www.live365.com, port 20657
(11/19/02 22:34:43) Logging on to account for jasondolan
(11/19/02 22:34:43) Nanocaster log-in failed, no response from the server.
(11/19/02 22:34:43) Re-connect failed
(11/19/02 22:34:53) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:34:53) Connection made with server, www.live365.com, port 20657
(11/19/02 22:34:53) Logging on to account for jasondolan
(11/19/02 22:34:53) Nanocaster log-in failed, no response from the server.
(11/19/02 22:34:53) Re-connect failed
(11/19/02 22:35:04) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:35:04) Connection made with server, www.live365.com, port 20657
(11/19/02 22:35:04) Logging on to account for jasondolan
(11/19/02 22:35:04) Nanocaster log-in failed, no response from the server.
(11/19/02 22:35:04) Re-connect failed
(11/19/02 22:35:14) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:35:14) Connection made with server, www.live365.com, port 20657
(11/19/02 22:35:14) Logging on to account for jasondolan
(11/19/02 22:35:14) Nanocaster log-in failed, no response from the server.
(11/19/02 22:35:15) Re-connect failed
(11/19/02 22:35:25) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:35:25) Connection made with server, www.live365.com, port 20657
(11/19/02 22:35:25) Logging on to account for jasondolan
(11/19/02 22:35:25) Nanocaster log-in failed, no response from the server.
(11/19/02 22:35:25) Re-connect failed
(11/19/02 22:35:35) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:35:35) Connection made with server, www.live365.com, port 20657
(11/19/02 22:35:35) Logging on to account for jasondolan
(11/19/02 22:35:35) Nanocaster log-in failed, no response from the server.
(11/19/02 22:35:35) Re-connect failed
(11/19/02 22:35:45) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:35:45) Connection made with server, www.live365.com, port 20657
(11/19/02 22:35:45) Logging on to account for jasondolan
(11/19/02 22:35:45) Nanocaster log-in failed, no response from the server.
(11/19/02 22:35:45) Re-connect failed
(11/19/02 22:35:55) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:35:55) Connection made with server, www.live365.com, port 20657
(11/19/02 22:35:55) Logging on to account for jasondolan
(11/19/02 22:35:55) Nanocaster log-in failed, no response from the server.
(11/19/02 22:35:55) Re-connect failed
(11/19/02 22:36:05) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:36:05) Connection made with server, www.live365.com, port 20657
(11/19/02 22:36:05) Logging on to account for jasondolan
(11/19/02 22:36:05) Nanocaster log-in failed, no response from the server.
(11/19/02 22:36:05) Re-connect failed
(11/19/02 22:36:15) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:36:15) Connection made with server, www.live365.com, port 20657
(11/19/02 22:36:15) Logging on to account for jasondolan
(11/19/02 22:36:15) Nanocaster log-in failed, no response from the server.
(11/19/02 22:36:15) Re-connect failed
(11/19/02 22:36:25) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:36:25) Connection made with server, www.live365.com, port 20657
(11/19/02 22:36:25) Logging on to account for jasondolan
(11/19/02 22:36:25) Nanocaster log-in failed, no response from the server.
(11/19/02 22:36:25) Re-connect failed
(11/19/02 22:36:35) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:36:35) Connection made with server, www.live365.com, port 20657
(11/19/02 22:36:35) Logging on to account for jasondolan
(11/19/02 22:36:35) Nanocaster log-in failed, no response from the server.
(11/19/02 22:36:35) Re-connect failed
(11/19/02 22:36:45) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:36:45) Connection made with server, www.live365.com, port 20657
(11/19/02 22:36:45) Logging on to account for jasondolan
(11/19/02 22:36:45) Nanocaster log-in failed, no response from the server.
(11/19/02 22:36:45) Re-connect failed
(11/19/02 22:36:55) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:36:55) Connection made with server, www.live365.com, port 20657
(11/19/02 22:36:55) Logging on to account for jasondolan
(11/19/02 22:36:55) Nanocaster log-in failed, no response from the server.
(11/19/02 22:36:55) Re-connect failed
(11/19/02 22:37:05) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:37:05) Connection made with server, www.live365.com, port 20657
(11/19/02 22:37:05) Logging on to account for jasondolan
(11/19/02 22:37:05) Nanocaster log-in failed, no response from the server.
(11/19/02 22:37:05) Re-connect failed
(11/19/02 22:37:15) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:37:15) Connection made with server, www.live365.com, port 20657
(11/19/02 22:37:15) Logging on to account for jasondolan
(11/19/02 22:37:15) Nanocaster log-in failed, no response from the server.
(11/19/02 22:37:15) Re-connect failed
(11/19/02 22:37:25) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:37:25) Connection made with server, www.live365.com, port 20657
(11/19/02 22:37:25) Logging on to account for jasondolan
(11/19/02 22:37:25) Nanocaster log-in failed, no response from the server.
(11/19/02 22:37:25) Re-connect failed
(11/19/02 22:37:35) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:37:35) Connection made with server, www.live365.com, port 20657
(11/19/02 22:37:35) Logging on to account for jasondolan
(11/19/02 22:37:35) Nanocaster log-in failed, no response from the server.
(11/19/02 22:37:35) Re-connect failed
(11/19/02 22:37:45) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:37:45) Connection made with server, www.live365.com, port 20657
(11/19/02 22:37:45) Logging on to account for jasondolan
(11/19/02 22:37:45) Nanocaster log-in failed, no response from the server.
(11/19/02 22:37:45) Re-connect failed
(11/19/02 22:37:55) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:37:55) Connection made with server, www.live365.com, port 20657
(11/19/02 22:37:55) Logging on to account for jasondolan
(11/19/02 22:37:55) Nanocaster log-in failed, no response from the server.
(11/19/02 22:37:55) Re-connect failed
(11/19/02 22:38:05) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:38:05) Connection made with server, www.live365.com, port 20657
(11/19/02 22:38:05) Logging on to account for jasondolan
(11/19/02 22:38:05) Nanocaster log-in failed, no response from the server.
(11/19/02 22:38:05) Re-connect failed
(11/19/02 22:38:15) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:38:15) Connection made with server, www.live365.com, port 20657
(11/19/02 22:38:15) Logging on to account for jasondolan
(11/19/02 22:38:15) Nanocaster log-in failed, no response from the server.
(11/19/02 22:38:15) Re-connect failed
(11/19/02 22:38:25) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:38:25) Connection made with server, www.live365.com, port 20657
(11/19/02 22:38:25) Logging on to account for jasondolan
(11/19/02 22:38:25) Nanocaster log-in failed, no response from the server.
(11/19/02 22:38:25) Re-connect failed
(11/19/02 22:38:35) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:38:35) Connection made with server, www.live365.com, port 20657
(11/19/02 22:38:35) Logging on to account for jasondolan
(11/19/02 22:38:35) Nanocaster log-in failed, no response from the server.
(11/19/02 22:38:35) Re-connect failed
(11/19/02 22:38:45) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:38:45) Connection made with server, www.live365.com, port 20657
(11/19/02 22:38:45) Logging on to account for jasondolan
(11/19/02 22:38:45) Nanocaster log-in failed, no response from the server.
(11/19/02 22:38:45) Re-connect failed
(11/19/02 22:38:5Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:38:5Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:38:5Cool Logging on to account for jasondolan
(11/19/02 22:38:5Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:38:5Cool Re-connect failed
(11/19/02 22:39:0Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:39:0Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:39:0Cool Logging on to account for jasondolan
(11/19/02 22:39:0Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:39:0Cool Re-connect failed
(11/19/02 22:39:1Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:39:1Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:39:1Cool Logging on to account for jasondolan
(11/19/02 22:39:1Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:39:1Cool Re-connect failed
(11/19/02 22:39:2Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:39:2Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:39:2Cool Logging on to account for jasondolan
(11/19/02 22:39:2Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:39:2Cool Re-connect failed
(11/19/02 22:39:3Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:39:3Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:39:3Cool Logging on to account for jasondolan
(11/19/02 22:39:3Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:39:3Cool Re-connect failed
(11/19/02 22:39:4Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:39:4Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:39:4Cool Logging on to account for jasondolan
(11/19/02 22:39:4Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:39:4Cool Re-connect failed
(11/19/02 22:39:5Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:39:5Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:39:5Cool Logging on to account for jasondolan
(11/19/02 22:39:5Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:39:5Cool Re-connect failed
(11/19/02 22:40:0Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:40:0Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:40:0Cool Logging on to account for jasondolan
(11/19/02 22:40:0Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:40:0Cool Re-connect failed
(11/19/02 22:40:1Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:40:1Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:40:1Cool Logging on to account for jasondolan
(11/19/02 22:40:1Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:40:1Cool Re-connect failed
(11/19/02 22:40:2Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:40:2Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:40:2Cool Logging on to account for jasondolan
(11/19/02 22:40:2Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:40:2Cool Re-connect failed
(11/19/02 22:40:3Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:40:3Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:40:3Cool Logging on to account for jasondolan
(11/19/02 22:40:3Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:40:3Cool Re-connect failed
(11/19/02 22:40:4Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:40:4Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:40:4Cool Logging on to account for jasondolan
(11/19/02 22:40:4Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:40:4Cool Re-connect failed
(11/19/02 22:40:5Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:40:5Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:40:5Cool Logging on to account for jasondolan
(11/19/02 22:40:5Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:40:5Cool Re-connect failed
(11/19/02 22:41:0Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:41:0Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:41:0Cool Logging on to account for jasondolan
(11/19/02 22:41:0Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:41:0Cool Re-connect failed
(11/19/02 22:41:1Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:41:1Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:41:1Cool Logging on to account for jasondolan
(11/19/02 22:41:1Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:41:1Cool Re-connect failed
(11/19/02 22:41:2Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:41:2Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:41:2Cool Logging on to account for jasondolan
(11/19/02 22:41:2Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:41:2Cool Re-connect failed
(11/19/02 22:41:3Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:41:3Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:41:3Cool Logging on to account for jasondolan
(11/19/02 22:41:3Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:41:3Cool Re-connect failed
(11/19/02 22:41:4Cool Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:41:4Cool Connection made with server, www.live365.com, port 20657
(11/19/02 22:41:4Cool Logging on to account for jasondolan
(11/19/02 22:41:4Cool Nanocaster log-in failed, no response from the server.
(11/19/02 22:41:4Cool Re-connect failed
(11/19/02 22:41:59) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:41:59) Connection made with server, www.live365.com, port 20657
(11/19/02 22:41:59) Logging on to account for jasondolan
(11/19/02 22:41:59) Nanocaster log-in failed, no response from the server.
(11/19/02 22:41:59) Re-connect failed
(11/19/02 22:42:09) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:42:09) Connection made with server, www.live365.com, port 20657
(11/19/02 22:42:09) Logging on to account for jasondolan
(11/19/02 22:42:09) Nanocaster log-in failed, no response from the server.
(11/19/02 22:42:09) Re-connect failed
(11/19/02 22:42:19) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:42:19) Connection made with server, www.live365.com, port 20657
(11/19/02 22:42:19) Logging on to account for jasondolan
(11/19/02 22:42:19) Nanocaster log-in failed, no response from the server.
(11/19/02 22:42:19) Re-connect failed
(11/19/02 22:42:29) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:42:29) Connection made with server, www.live365.com, port 20657
(11/19/02 22:42:29) Logging on to account for jasondolan
(11/19/02 22:42:29) Nanocaster log-in failed, no response from the server.
(11/19/02 22:42:29) Re-connect failed
(11/19/02 22:42:39) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:42:39) Connection made with server, www.live365.com, port 20657
(11/19/02 22:42:39) Logging on to account for jasondolan
(11/19/02 22:42:39) Nanocaster log-in failed, no response from the server.
(11/19/02 22:42:39) Re-connect failed
(11/19/02 22:42:51) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:42:51) Connection made with server, www.live365.com, port 20657
(11/19/02 22:42:51) Logging on to account for jasondolan
(11/19/02 22:42:51) Nanocaster log-in failed, no response from the server.
(11/19/02 22:42:51) Re-connect failed
(11/19/02 22:43:01) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:43:01) Connection made with server, www.live365.com, port 20657
(11/19/02 22:43:01) Logging on to account for jasondolan
(11/19/02 22:43:01) Nanocaster log-in failed, no response from the server.
(11/19/02 22:43:01) Re-connect failed
(11/19/02 22:43:11) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:43:11) Connection made with server, www.live365.com, port 20657
(11/19/02 22:43:11) Logging on to account for jasondolan
(11/19/02 22:43:11) Nanocaster log-in failed, no response from the server.
(11/19/02 22:43:11) Re-connect failed
(11/19/02 22:43:21) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:43:21) Connection made with server, www.live365.com, port 20657
(11/19/02 22:43:21) Logging on to account for jasondolan
(11/19/02 22:43:21) Nanocaster log-in failed, no response from the server.
(11/19/02 22:43:21) Re-connect failed
(11/19/02 22:43:31) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:43:31) Connection made with server, www.live365.com, port 20657
(11/19/02 22:43:31) Logging on to account for jasondolan
(11/19/02 22:43:31) Nanocaster log-in failed, no response from the server.
(11/19/02 22:43:31) Re-connect failed
(11/19/02 22:43:41) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:43:41) Connection made with server, www.live365.com, port 20657
(11/19/02 22:43:41) Logging on to account for jasondolan
(11/19/02 22:43:41) Nanocaster log-in failed, no response from the server.
(11/19/02 22:43:41) Re-connect failed
(11/19/02 22:43:51) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:43:51) Connection made with server, www.live365.com, port 20657
(11/19/02 22:43:51) Logging on to account for jasondolan
(11/19/02 22:43:51) Nanocaster log-in failed, no response from the server.
(11/19/02 22:43:51) Re-connect failed
(11/19/02 22:44:01) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:44:01) Connection made with server, www.live365.com, port 20657
(11/19/02 22:44:01) Logging on to account for jasondolan
(11/19/02 22:44:01) Nanocaster log-in failed, no response from the server.
(11/19/02 22:44:01) Re-connect failed
(11/19/02 22:44:11) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:44:11) Connection made with server, www.live365.com, port 20657
(11/19/02 22:44:11) Logging on to account for jasondolan
(11/19/02 22:44:11) Nanocaster log-in failed, no response from the server.
(11/19/02 22:44:11) Re-connect failed
(11/19/02 22:44:21) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:44:21) Connection made with server, www.live365.com, port 20657
(11/19/02 22:44:21) Logging on to account for jasondolan
(11/19/02 22:44:21) Nanocaster log-in failed, no response from the server.
(11/19/02 22:44:21) Re-connect failed
(11/19/02 22:44:31) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:44:31) Connection made with server, www.live365.com, port 20657
(11/19/02 22:44:31) Logging on to account for jasondolan
(11/19/02 22:44:31) Nanocaster log-in failed, no response from the server.
(11/19/02 22:44:31) Re-connect failed
(11/19/02 22:44:41) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:44:41) Connection made with server, www.live365.com, port 20657
(11/19/02 22:44:41) Logging on to account for jasondolan
(11/19/02 22:44:41) Nanocaster log-in failed, no response from the server.
(11/19/02 22:44:41) Re-connect failed
(11/19/02 22:44:51) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:44:51) Connection made with server, www.live365.com, port 20657
(11/19/02 22:44:51) Logging on to account for jasondolan
(11/19/02 22:44:51) Nanocaster log-in failed, no response from the server.
(11/19/02 22:44:51) Re-connect failed
(11/19/02 22:45:01) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:45:01) Connection made with server, www.live365.com, port 20657
(11/19/02 22:45:01) Logging on to account for jasondolan
(11/19/02 22:45:01) Nanocaster log-in failed, no response from the server.
(11/19/02 22:45:01) Re-connect failed
(11/19/02 22:45:12) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:45:12) Connection made with server, www.live365.com, port 20657
(11/19/02 22:45:12) Logging on to account for jasondolan
(11/19/02 22:45:12) Nanocaster log-in failed, no response from the server.
(11/19/02 22:45:12) Re-connect failed
(11/19/02 22:45:22) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:45:22) Connection made with server, www.live365.com, port 20657
(11/19/02 22:45:22) Logging on to account for jasondolan
(11/19/02 22:45:22) Nanocaster log-in failed, no response from the server.
(11/19/02 22:45:22) Re-connect failed
(11/19/02 22:45:32) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:45:32) Connection made with server, www.live365.com, port 20657
(11/19/02 22:45:32) Logging on to account for jasondolan
(11/19/02 22:45:32) Nanocaster log-in failed, no response from the server.
(11/19/02 22:45:32) Re-connect failed
(11/19/02 22:45:42) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:45:42) Connection made with server, www.live365.com, port 20657
(11/19/02 22:45:42) Logging on to account for jasondolan
(11/19/02 22:45:42) Nanocaster log-in failed, no response from the server.
(11/19/02 22:45:42) Re-connect failed
(11/19/02 22:45:52) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:45:52) Connection made with server, www.live365.com, port 20657
(11/19/02 22:45:52) Logging on to account for jasondolan
(11/19/02 22:45:52) Nanocaster log-in failed, no response from the server.
(11/19/02 22:45:52) Re-connect failed
(11/19/02 22:46:02) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:46:02) Connection made with server, www.live365.com, port 20657
(11/19/02 22:46:02) Logging on to account for jasondolan
(11/19/02 22:46:02) Nanocaster log-in failed, no response from the server.
(11/19/02 22:46:02) Re-connect failed
(11/19/02 22:46:12) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:46:12) Connection made with server, www.live365.com, port 20657
(11/19/02 22:46:12) Logging on to account for jasondolan
(11/19/02 22:46:12) Nanocaster log-in failed, no response from the server.
(11/19/02 22:46:12) Re-connect failed
(11/19/02 22:46:22) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:46:22) Connection made with server, www.live365.com, port 20657
(11/19/02 22:46:22) Logging on to account for jasondolan
(11/19/02 22:46:22) Nanocaster log-in failed, no response from the server.
(11/19/02 22:46:22) Re-connect failed
(11/19/02 22:46:32) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:46:32) Connection made with server, www.live365.com, port 20657
(11/19/02 22:46:32) Logging on to account for jasondolan
(11/19/02 22:46:32) Nanocaster log-in failed, no response from the server.
(11/19/02 22:46:32) Re-connect failed
(11/19/02 22:46:42) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:46:42) Connection made with server, www.live365.com, port 20657
(11/19/02 22:46:42) Logging on to account for jasondolan
(11/19/02 22:46:42) Nanocaster log-in failed, no response from the server.
(11/19/02 22:46:42) Re-connect failed
(11/19/02 22:46:52) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:46:52) Connection made with server, www.live365.com, port 20657
(11/19/02 22:46:52) Logging on to account for jasondolan
(11/19/02 22:46:52) Nanocaster log-in failed, no response from the server.
(11/19/02 22:46:52) Re-connect failed
(11/19/02 22:47:02) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:47:02) Connection made with server, www.live365.com, port 20657
(11/19/02 22:47:02) Logging on to account for jasondolan
(11/19/02 22:47:02) Nanocaster log-in failed, no response from the server.
(11/19/02 22:47:02) Re-connect failed
(11/19/02 22:47:12) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:47:12) Connection made with server, www.live365.com, port 20657
(11/19/02 22:47:12) Logging on to account for jasondolan
(11/19/02 22:47:12) Nanocaster log-in failed, no response from the server.
(11/19/02 22:47:12) Re-connect failed
(11/19/02 22:47:22) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:47:22) Connection made with server, www.live365.com, port 20657
(11/19/02 22:47:22) Logging on to account for jasondolan
(11/19/02 22:47:22) Nanocaster log-in failed, no response from the server.
(11/19/02 22:47:22) Re-connect failed
(11/19/02 22:47:32) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:47:32) Connection made with server, www.live365.com, port 20657
(11/19/02 22:47:32) Logging on to account for jasondolan
(11/19/02 22:47:32) Nanocaster log-in failed, no response from the server.
(11/19/02 22:47:32) Re-connect failed
(11/19/02 22:47:43) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:47:43) Connection made with server, www.live365.com, port 20657
(11/19/02 22:47:43) Logging on to account for jasondolan
(11/19/02 22:47:43) Nanocaster log-in failed, no response from the server.
(11/19/02 22:47:43) Re-connect failed
(11/19/02 22:47:53) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:47:53) Connection made with server, www.live365.com, port 20657
(11/19/02 22:47:53) Logging on to account for jasondolan
(11/19/02 22:47:53) Nanocaster log-in failed, no response from the server.
(11/19/02 22:47:53) Re-connect failed
(11/19/02 22:48:03) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:48:03) Connection made with server, www.live365.com, port 20657
(11/19/02 22:48:03) Logging on to account for jasondolan
(11/19/02 22:48:03) Nanocaster log-in failed, no response from the server.
(11/19/02 22:48:03) Re-connect failed
(11/19/02 22:48:13) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:48:13) Connection made with server, www.live365.com, port 20657
(11/19/02 22:48:13) Logging on to account for jasondolan
(11/19/02 22:48:13) Nanocaster log-in failed, no response from the server.
(11/19/02 22:48:13) Re-connect failed
(11/19/02 22:48:23) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:48:23) Connection made with server, www.live365.com, port 20657
(11/19/02 22:48:23) Logging on to account for jasondolan
(11/19/02 22:48:23) Nanocaster log-in failed, no response from the server.
(11/19/02 22:48:23) Re-connect failed
(11/19/02 22:48:34) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:48:34) Connection made with server, www.live365.com, port 20657
(11/19/02 22:48:34) Logging on to account for jasondolan
(11/19/02 22:48:34) Nanocaster log-in failed, no response from the server.
(11/19/02 22:48:34) Re-connect failed
(11/19/02 22:48:44) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:48:44) Connection made with server, www.live365.com, port 20657
(11/19/02 22:48:44) Logging on to account for jasondolan
(11/19/02 22:48:44) Nanocaster log-in failed, no response from the server.
(11/19/02 22:48:44) Re-connect failed
(11/19/02 22:48:54) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:48:54) Connection made with server, www.live365.com, port 20657
(11/19/02 22:48:54) Logging on to account for jasondolan
(11/19/02 22:48:54) Nanocaster log-in failed, no response from the server.
(11/19/02 22:48:54) Re-connect failed
(11/19/02 22:49:04) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:49:04) Connection made with server, www.live365.com, port 20657
(11/19/02 22:49:04) Logging on to account for jasondolan
(11/19/02 22:49:04) Nanocaster log-in failed, no response from the server.
(11/19/02 22:49:04) Re-connect failed
(11/19/02 22:49:14) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:49:14) Connection made with server, www.live365.com, port 20657
(11/19/02 22:49:14) Logging on to account for jasondolan
(11/19/02 22:49:14) Nanocaster log-in failed, no response from the server.
(11/19/02 22:49:14) Re-connect failed
(11/19/02 22:49:24) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:49:24) Connection made with server, www.live365.com, port 20657
(11/19/02 22:49:24) Logging on to account for jasondolan
(11/19/02 22:49:24) Nanocaster log-in failed, no response from the server.
(11/19/02 22:49:24) Re-connect failed
(11/19/02 22:49:34) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:49:34) Connection made with server, www.live365.com, port 20657
(11/19/02 22:49:34) Logging on to account for jasondolan
(11/19/02 22:49:34) Nanocaster log-in failed, no response from the server.
(11/19/02 22:49:34) Re-connect failed
(11/19/02 22:49:44) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:49:44) Connection made with server, www.live365.com, port 20657
(11/19/02 22:49:44) Logging on to account for jasondolan
(11/19/02 22:49:44) Nanocaster log-in failed, no response from the server.
(11/19/02 22:49:44) Re-connect failed
(11/19/02 22:49:54) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:49:54) Connection made with server, www.live365.com, port 20657
(11/19/02 22:49:54) Logging on to account for jasondolan
(11/19/02 22:49:54) Nanocaster log-in failed, no response from the server.
(11/19/02 22:49:54) Re-connect failed
(11/19/02 22:50:04) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:50:04) Connection made with server, www.live365.com, port 20657
(11/19/02 22:50:04) Logging on to account for jasondolan
(11/19/02 22:50:04) Nanocaster log-in failed, no response from the server.
(11/19/02 22:50:04) Re-connect failed
(11/19/02 22:50:14) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:50:14) Connection made with server, www.live365.com, port 20657
(11/19/02 22:50:14) Logging on to account for jasondolan
(11/19/02 22:50:14) Nanocaster log-in failed, no response from the server.
(11/19/02 22:50:14) Re-connect failed
(11/19/02 22:50:24) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:50:24) Connection made with server, www.live365.com, port 20657
(11/19/02 22:50:24) Logging on to account for jasondolan
(11/19/02 22:50:24) Nanocaster log-in failed, no response from the server.
(11/19/02 22:50:24) Re-connect failed
(11/19/02 22:50:34) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:50:34) Connection made with server, www.live365.com, port 20657
(11/19/02 22:50:34) Logging on to account for jasondolan
(11/19/02 22:50:34) Nanocaster log-in failed, no response from the server.
(11/19/02 22:50:34) Re-connect failed
(11/19/02 22:50:44) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:50:44) Connection made with server, www.live365.com, port 20657
(11/19/02 22:50:44) Logging on to account for jasondolan
(11/19/02 22:50:44) Nanocaster log-in failed, no response from the server.
(11/19/02 22:50:44) Re-connect failed
(11/19/02 22:50:54) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:50:54) Connection made with server, www.live365.com, port 20657
(11/19/02 22:50:54) Logging on to account for jasondolan
(11/19/02 22:50:54) Nanocaster log-in failed, no response from the server.
(11/19/02 22:50:54) Re-connect failed
(11/19/02 22:51:04) Line down, attempting to reconnect. The line has dropped 2 times.
(11/19/02 22:51:04) Connection made with server, www.live365.com, port 20657
(11/19/02 22:51:04) Logging on to account for jasondolan
(11/19/02 22:51:04) Nanocaster log-in failed, no response from the server.
(11/19/02 22:51:04) Re-co
Saturn
RE: Message For PlusNet Support Re: Disconnections
So which bit do you feel shows there might be a problem?
Sorry, only joking! Just couldn't resist on this occasion.
I hope you never typed that all out because if you did it was a waste of time. If you look at there last communications in the service status for connectivity you will see that they are acknowledging the fact and it could have saved you some time.
I see that now m8.
and also see they can announce work for a day,
then cancel it to another just as quick.
so i lost my Smiley feeling again.
Nah i didn't type all that!. i copy and pasted it from the tonights log file Smiley
Jason
How do you create that log?
Jason,
I'd say that your isssue is associated with our latest announcement that we made through our service status pages yeaterday.
The link to the announcement is provided below:
http://portal.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=9
Best Regards,
Dave.
Dave Watson.
| David Watson. Unmetered & ADSL solutions
| Technical Support. for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
