Maximum charge when going over quota on bandwidth.
I’ve just upgraded to a 1MB connection, with a 4GB a month usage. As I understand for every 1GB I go over I’ld be charged £2 more.
Can someone confirm what the maximum I would be charged on this account? For sake of argument say I used 20GB in one month. Looking at the pricing options I’m 6 steps away from Premium, 5,6..9, Premium. Am I correct in thinking I would only be charged £12 extra on this account if I downloaded the 20GB, or do you keep charging £2 for every GB.
There was a figure bandied around a few weeks ago that the absolute maximum charge would be £99 :x
I'm not sure if that's still the case as I did hear that it had been reduced to £49. :?
Not sure how you come up with the £12-00.
If you used 20 Gig on a 4 Gig limit then you will be over by 16 Gig or £32
From what I've read, the max you'll ever get charged is £49, but if you regurarly reach that every month, then you'd be better off on premier!
According to this FAQ...
If you're an existing Broadband Home customer and you signed up before Thursday 26th August 2004...there's a maximum cost for bandwidth depending on the speed of your package:
512k > £24.99 a month
1Mb > £34.99 a month
2Mb > £44.99 a month
Note that changing speed / included bandwidth AFTER 26th August would mean that you do not qualify for that. For all other customers it simply says "there is no maximum spend for bandwidth" - although I was sure there was a £99 figure set?
The £49 figure is only if you used the amount quoted where it stated that.. If you go over that figure you will still pay more so the £49 is not the max you would pay.
Plusnet consider any products that have been activated or upgraded since Aug 26th to not have a spending limit.
There is supposed to be a change to this area (was due on 8th Oct - what happened to it?) which was to allow you to set your own spend limit but so far this has not appeared.
can i change my bandwidth settings even when my broadband hasn't been activated yet? i don't want the adsl tracker to restart: it's already slow as it is now ><
Yes, just raise a contact us ticket requesting what limit you want when your connection is activated. What you can't do at thios stage is change your ADSL speed, but bandwidth within a speeed is changeable.
cheers mate
If you think about it, the cost of the premium service doesn't really relate to the charging rate / limit for the pay as you use service. After all, if you buy a pay as you go phone the maximum call charges aren't pegged to the price of a monthly contract.
If that was how plusnet operated, we'd all pay for the minimum contract safe in the knowledge that if we had a heavy month it would only cost maybe £20 more.
Sorry. I am not quite surwe which way you swing on the issue, depending on that, you have some intetresting points.
